Competition: kinematic simulation of a coupling gear
kwahoo
Re: Competition: kinematic simulation of a coupling gear
Post by kwahoo »
NewJoker wrote: Fri May 20, 2022 2:05 pm
Yes, the sketcher with its constraints, DOF handling and mouse dragging can be very useful for simple geometric analysis of a mechanism but won't provide you the data needed in most cases - positions, velocities and accelerations (not to even mention forces and moments) of points and links belonging to the mechanism throughout its whole range of motion under applied velocity, for example.
That's possible with proper sketches in commercial software: https://www.youtube.com/watch?v=pBczBrM7uq0
You can add "drive" to a sketch and read position of every vertex, with a simple script. To show things as simple as possible, I made an example with 3 lines:
kinem.FCStd
(4.9 KiB) Downloaded 18 times
This script will move angle constraint from 10 deg to 40 deg with 1 deg step, and print position of Vertex3:
import FreeCAD as App, FreeCADGui as Gui, Part, time
from PySide2 import QtGui,QtCore
class Animation(object):
    def __init__(self):
        App.Console.PrintMessage('init')
        self.timer = QtCore.QTimer()
        QtCore.QObject.connect(self.timer, QtCore.SIGNAL("timeout()"), self.my_update)
        self.timer.start(500) #500ms for step, adjust to performance of the PC
        self.an = 10
        self.end = 40
    def my_update(self):
        self.an = self.an + 1
        App.ActiveDocument.getObjectsByLabel("Sketch")[0].setDatum(6,App.Units.Quantity(str(self.an)+' deg')) #angle Constraint7 (6+1, because Sketcher starts counting from 1 not 0)
        p1 = App.ActiveDocument.getObjectsByLabel("Sketch")[0].Shape.Vertexes[2].Point #Sketch.Vertex3
        print(str(self.an), str(p1))
        if self.an > self.end:
            self.stop()
    def stop(self):
        self.timer.stop()
animation = Animation()
Console output:
18:14:40  21 Vector (-24.33471798228596, 37.3432170597076, 0.0)
18:14:41  22 Vector (-24.984263737107035, 37.08735418248287, 0.0)
18:14:41  23 Vector (-25.629245140037973, 36.820194137900906, 0.0)
Then you can easily calculate velocity, since it is the first derivative of displacement and acceleration (second derivative). Finally you can create some graphs with FreeCAD.plot() https://wiki.freecadweb.org/Plot_MultiAxes_tutorial
Also there is another more fancy tool: Assembly3 skeleton sketch https://github.com/realthunder/FreeCAD_ ... ton-Sketch
It works in 3D, and has dedicated tool for tracing vertices.
adrianinsaval
Post by adrianinsaval »
wasn't there a recent announcement of a 2D kinematics workbench?
NewJoker
Post by NewJoker »
kwahoo wrote: Sat May 21, 2022 4:21 pm You can add "drive" to a sketch and read position of every vertex, with a simple script.
Thank you for sharing this. I think that it would be great to implement a workbench or tool that could do this automatically. Especially that there are no FOSS alternatives for that at the moment. For now, I created a GitHub feature request to document this idea:
https://github.com/FreeCAD/FreeCAD/issues/6908
By the way, do you know if this approach could be extended to obtain also the forces and moments ?
adrianinsaval wrote: Sat May 21, 2022 11:33 pm wasn't there a recent announcement of a 2D kinematics workbench?
Do you mean this ?
https://forum.freecadweb.org/viewtopic.php?f=9&t=66567
adrianinsaval
NewJoker wrote: Sun May 22, 2022 10:31 am For now, I created a GitHub feature request to document this idea:
Isn't it out of scope for the main repo?
yes, does it not satisfy your needs?
NewJoker
Post by NewJoker »
adrianinsaval wrote: Sun May 22, 2022 2:42 pm Isn't it out of scope for the main repo?
I don't think so, suggestions for new workbenches are also placed there. For example: https://github.com/FreeCAD/FreeCAD/issues/6439
I added it there in the fond hope that it may become a built-in feature. But even if it's created as another add-on, I think that the report still fits there until someone creates a separate repository for a new workbench to develop it.
adrianinsaval wrote: Sun May 22, 2022 2:42 pm yes, does it not satisfy your needs?
It looks very promising (even though it's still in development and can't plot accelerations and forces, for example) but it doesn't operate on sketches and requires assemblies of 3D bodies so it's more like this workbench: https://forum.freecadweb.org/viewtopic.php?f=18&t=39165
than a simple tool to animate sketches and do some calculations on them (which is the focus of my GitHub report).
kwahoo
Post by kwahoo »
Well, yes. If you know masses and where they are placed, the rest is Newton's 2nd law.
Post by Kunda1 »
NewJoker
Post by NewJoker »
This FR was closed because it was too wide. I created a new one, limited to just a small tool for kinematic analysis on sketches: issue #7248
