Civil Engineering Design functions
Re: Civil Engineering Design functions
Postby Kunda1 » Tue May 02, 2017 4:05 pm
Related threads
Civil engineering feature implementation (a continuation to this thread)
https://forum.freecadweb.org/viewtopic.php?f=8&t=22277
New experimental feature: Hi-res property in Arch (indirectly related but shows arch examples of a cityscape)
https://forum.freecadweb.org/viewtopic. ... 45#p172245
Postby Kunda1 » Thu May 25, 2017 10:34 am
microelly2 wrote:ping
@microelly2 I'm working on improving the FC Addon Manager. I'm doing this by improving the descriptions of all current addons and also working on the metadata side for a pre-requisite dependency checker
I was hoping we could add more comprehensive README.md for your Geodata and nurbs repos.
Specifically:
  • add a repo summary
  • add a more comprehensive 'about' section
  • add the 'freecad' tag/subject to the repo
  • add installation instructions
  • add a screenshot or animated gif
  • add your YouTube links
  • a link back to this thread for further discussion or whatever you deem fit
  • Roadmap
  • Development guidelines for those who wish to contribute
  • eventually add a metadata file for each addon
Thoughts?
microelly2
Postby microelly2 » Fri May 26, 2017 8:46 am
Specifically:
  • Roadmap
Thoughts?
Good to have this task list. I think I can do all this step by step next weeks.
Postby Kunda1 » Wed Jun 14, 2017 1:19 pm
microelly2 wrote: Good to have this task list. I think I can do all this step by step next weeks.
Any progress? ;)
microelly2
Postby microelly2 » Fri Jun 16, 2017 3:17 pm
Any progress? ;)
At the moment I learn doxygen for python
microelly2
Postby microelly2 » Wed Jun 28, 2017 2:57 pm
I have started to publish with doxygen,
a lot of possibilities and a lot of work ...
https://freecadbuch.de/doxygen/geodat/html/index.html
at the moment there is a list of the videos and some first module documentation.
Postby Kunda1 » Wed Jun 28, 2017 3:10 pm
@microelly2 nice work so far!
suhasj123
Postby suhasj123 » Tue Jul 18, 2017 9:37 am
I am giving some point here for about design functions as follow
Modeling:
This is the heart of structural design. When you start sketching the model, there are several options. You can either draw it in a grid or use a template.
You can also import the file from Auto-CAD and even see the supposed image of your model after creation. The following steps are done in modelling
Materials
Some of the most used materials are pre-defined in the software. The material which suits to our building is taken. For designing a concrete building, we choose concrete as the material for beams, columns and slabs. The walls could either be of masonry or concrete depending on the loads coming on the building. Other materials like steel and aluminium are also used in the construction. For the concrete section, rebar are used for reinforcement.
Other material properties are:
Steel:
Modulus of elasticity of steel, E
Poisson’s ratio, µ
Steel density
Yield strength of steel, Fy
Concrete:
Basic strength of concrete, Fck
Density of concrete
Geometry
Beams and columns are given length, width and depth. Slab is given thickness and the slab type is defined as membrane element which is to represent only the in-plane stiffness of the members.
Boundary conditions:
To select a proper boundary condition has an important role in structural analysis. The modeling of support conditions at expansion joints and bearings require a careful consideration of continuity of each translational and rotational component of displacement.
It is natural to use simple supports for a static analysis.
Load calculation:
The loads needed for the building are defined here. The software takes the loads according to the code IS 456:2000 which is pre-installed. The loads which are defined and applied to the building are:
Dead load: Load on a structure due to its own weight.
Live load: This is the load due to moving weight. The live load differs for different structure types.
Earthquake load: This load is the total force that an earthquake can exert on a structure.
Wind load: This is a distinct load on the structure due to the intensity of the wind.
Load application:
Here the loads are applied on the sections and slab and the seismic and the wind loads are employed by software. If the wall is not included then the frame loads are put on the beams.
Load combination:
It’s our duty to design a safe and serviceable structure and in order to do so we must predict the magnitudes of various loads that are likely to be applied to the structure over its lifetime.
Hence to account for the probability of the simultaneous application of various load types, several load combinations are applied on the structure.
These load combinations can be created by selecting the Indian code and also with the help of auto load combinations where they are generated by the software.
Analysis:
The structure will be analyzed. Results from the analysis like displacements, responses, bending moment, shear forces, storey drifts can be seen on the structure. It displays results in graphical forms and also display real time-history displacements and yield reports. The deformed geometry of the building can be portrayed based on any loads or any combination of loads.
Design:
A concrete design is done as per IS 456:2000 and the steel design is done according to IS 800. After the information needed for the design is shared, the software performs the design for every structural element. The design is created, depending on the need.
Details are provided in some software, where the rebar used must be defined. The detailed components include concrete beams, columns and walls, steel framing, beam schedules, column schedules and connections.
Result:
After the structural analysis, it is created to find out the steel used for the reinforcement for columns and beams. Results from the analysis like displacements, bending moment, shear forces, storey drifts could be seen on the structure. For columns, the axial forces that come on it, the bending moment and the shear forces can be obtained.
Some important points to be considered:
bernd
Postby bernd » Wed Jul 19, 2017 4:40 am
@suhasj123
Interesting post but in the wrong topic. Your post is about structural design, this topic is about civil engineering design.
You should have a look at FreeCAD FEM Workbench and FEM topic of the Forum. There are various topics about structural design. I would recommend to read this post before you get started with FreeCAD FEM. https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
bernd
Joel_graff
Postby Joel_graff » Wed Jul 19, 2017 1:12 pm
That's my fault. Technically, structural design is civil engineering. :) Should have focused it a bit by specifying this is about transportation engineering...
