See the Dimensions of the solid object
gooddealonly
Post by gooddealonly »
Is there any way to display the dimension on the solid object|
For example, no dimension is displayed on the solid object. If I click on a surface or an edge, the display makes no related indication on the model tree in the Combo View. If I want to see the dimension of any part, I have to find the named label of that part. That is if I name that part in a sensible manner, to begin with. It would be nice to be able to click on a part of the solid object, the dimensions such as the diameter, pad, or pocket length would be displayed. Better yet, the sketch of the selected part would be high light in the model tree.
Is there a way to do this?
I tried to label the different Pads, pockets, and sketches to make sense to me. Still, on some parts, I just could not come up with a good label for it. Since I built the model from the bottom up layer by layer, I have to find the correct sketch for that layer to see the dimensions.
popup-cleaner-4.FCStd
(719.44 KiB) Downloaded 11 times
bambuko
Re: See the Dimensions of the solid object
Post by bambuko »
Do you mean like that?
Screenshot from 2022-06-29 20.09.03.png (342.93 KiB) Viewed 1192 times
OS: Ubuntu Core 20 (Pantheon/pantheon)
Version: 2022.628.14555 (Git shallow)
Branch: (HEAD detached at 2022.06.28-edge)
Hash: abbaa46a30fd0e9629cbac1d76aaf623b5c5b9e7
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
gooddealonly
I am a new FreeCAD user, so please don't mind my ignorance.
Maybe, but I will have to see it on my computer to tell. There is not enough detail to see.
1) how did you get the value to display.
2) the Combo view model tree appears different on my newly installed FreeCAD 0.20. Yours look much nicer. How did you get the model tree to display like that?
3) Did you add the pointing red arrow?
Thanks.
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
mario52
Post by mario52 »
Hi gooddealonly
tray:
(with this only good deal)
Macro_FCInfo Image
Macro_FCInfo_ToolBar Image
Macro_FCInfoGlass Image
hi bambuko
mario
gooddealonly
And, how did you make the object transparent or see-through?
NewJoker
Post by NewJoker »
Here you can set the transparency: Std SetAppearance
Also, check this discussion about adding dimensions to 3D models: https://forum.freecadweb.org/viewtopic.php?f=3&t=67075
Shalmeneser
Post by Shalmeneser »
:idea:
popup-cleaner-4_SHALM.FCStd
(480.32 KiB) Downloaded 12 times
Capture d’écran 2022-06-30 000958.jpg (80 KiB) Viewed 1093 times
bambuko
Post by bambuko »
gooddealonly wrote: Wed Jun 29, 2022 7:56 pm 1) how did you get the value to display....
I am using Link branch of FreeCAD (forked from master branch), see: https://github.com/realthunder/FreeCAD
It has new features and enhancements not always available in master.
and... sorry if it confuses :?
gooddealonly wrote: Wed Jun 29, 2022 7:56 pm 2) the Combo view model tree appears different on my newly installed FreeCAD 0.20.
:mrgreen:
Apart from using Link branch I also use Dark stylesheet and have customised the panels etc.
It is all possible ;) but I guess you will need to learn to walk before you run....
gooddealonly wrote: Wed Jun 29, 2022 7:56 pm 3) Did you add the pointing red arrow?
yes -manually edited screen dump - just to point to, explain the features available
gooddealonly wrote: Wed Jun 29, 2022 8:51 pm And, how did you make the object transparent or see-through?
Apart from the link that @NewJoker has pointed to, see also:
https://wiki.freecadweb.org/Std_SelBoundingBox
https://forum.freecadweb.org/viewtopic. ... 10#p444387
mario52 wrote: Wed Jun 29, 2022 7:57 pm hi bambuko
Hi mario52 :P
In the absence of enhancements available in Link branch, your macros are excellent tools indeed.
mario52
Post by mario52 »
Hi
@bambuko thanks
mario
