[Feature Request] Rectangle from 3 corners
balrobs
Re: [Feature Request] Rectangle from 3 corners
Post by balrobs »
paddle wrote: Fri Aug 12, 2022 6:59 pm Yes it was a deliberate choice. It looks better imo.
Thanks for the explanation.
While testing the "rectangle by 3 corners" tool I noticed another strange behaviour.
If you start typing the rectangle by fixing all variables ("x of the 1st corner", "y of the first corner", "length", "angle (to HAxis)", "width") except "angle to the first edge", then move the mouse to find a suitable value for this variable and block it by typing its value in the input field, you get a completely different geometry than previously suggested in the preview.
This is what you see in the preview with "angle to first edge"=135°:
and this is what you get after typing in the value:
The same happens for the "rectangle by center and two points" command.
paddle
Post by paddle »
Hmm the angle gets applied on the wrong side. I'm not sure how to specify which angle needs to be set I need to search a bit.
Shalmeneser
Post by Shalmeneser »
Jee-Bee
Post by Jee-Bee »
paddle wrote: Sat Aug 13, 2022 12:46 pm Hmm the angle gets applied on the wrong side. I'm not sure how to specify which angle needs to be set I need to search a bit.
I like it that there are option to choose what angle you prefer
- Inner angle
- Outer angle up to 180 degrees
- Outer angle up to 360 degrees
nice for later ;)
paddle
Post by paddle »
Ok so there is a 'angle' constraint command that takes in parameters the pointPos of the lines and in this case it uses the correct angle automatically.
So now it's working properly. I pushed an additional commit fixing this problem.
For reference :
Gui::cmdAppObjectArgs(handler->sketchgui->getObject(), "addConstraint(Sketcher.Constraint('Angle',%d,%d,%d,%d,%f)) ",
         firstCurve + 1, 1, firstCurve, 2, innerAngle);
Instead of
Gui::cmdAppObjectArgs(handler->sketchgui->getObject(), "addConstraint(Sketcher.Constraint('Angle',%d,%d,%f)) ",
         firstCurve + 1, firstCurve, innerAngle);
Regarding allowing outer angles, it would add yet one more layer of complexity to the code and I'm not sure it's worth it.
