Contraining point onto two lines in one move
If I want to constrain point to crossing of two lines I have to constrain point to one line first and then repeat that to the second. Is there more optimal way?
I tried selecting point and two lines but then constraint cannot be applied. I think it is obvious that two constraints could be applied in that case speeding up the process.
Reason: fixed typo in thread title
Re: Contraining pointonto two lines in one move
I just tried that using a very recent version, and it worked fine.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.29849 (Git)
Branch: Master
Hash: 790bf5363e05c3de35d3c1350fd887b94f27a656
Installed mods:
* FeedsAndSpeeds 0.4.0
* FeedsAndSpeeds-master.zip
* Help 1.0.3
* offline-documentation
Seems to work for me:
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.21.29892 (Git)
Hash: c6ddc477331c655a30b071875c800b113d82f1b3
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.0.dev
Installed mods:
- Shalmeneser
Sketcher_ConstrainPointOnObject works correctly in
I'm happy to learn a new trick today.
OS: Windows 10 Version 1809
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: French/France (fr_FR)
Installed mods:
* fasteners 0.3.50
* fcgear 1.0.0
* Manipulator 1.4.9
* sheetmetal 0.2.53
Interestingly, I tried this just before I posted and could not make it work.
Now it works!
Now it works!
I usually do it by selecting all the three entities (two lines and one point) at once with a right-to-left box selection. Then I apply the constraint. Even fewer clicks.
Probably if you have posted some "relevant and requested" informations as told in the post at the top starting with "IMPORTANT:":PedjaS wrote: ↑Mon Aug 01, 2022 12:37 pm If I want to constrain point to crossing of two lines I have to constrain point to one line first and then repeat that to the second. Is there more optimal way?
https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
We could have an idea of what version you were using, as something could be different across OS or different versions, like a "Linux distribution supplied one" or an "official AppImage" or .....
Regards
Carlo D.
- Various other stuffs.
I tried this as a first attempt when this topic showed up.
It failed.
The reason was that I selected the endpoints of the lines as well as the lines themselves. The error message was that too many elements were selected.
Sooo, this works fine, but the user must be careful to avoid selecting the endpoints of the lines.
Gene
onekk wrote: ↑Tue Aug 02, 2022 1:14 pmProbably if you have posted some "relevant and requested" informations as told in the post at the top starting with "IMPORTANT:":PedjaS wrote: ↑Mon Aug 01, 2022 12:37 pm If I want to constrain point to crossing of two lines I have to constrain point to one line first and then repeat that to the second. Is there more optimal way?
Regards
Carlo D.
As you are so keen on this and very proficient in scripting, here is suggestion: make a script that disallows anyone to post anything on the forum without having to post that IMPORTANT information that you require. Maybe even better - ban them.
Especially, when IMPORTANT required information is actually not needed. Just for fun.
