[Bug?] Draft transformations with Copy don't take care of Std_Part
flachyjoe
Post by flachyjoe »
even if Draft object are created as children when an active Std_Part exists, Draft transformations ( Draft_Move, Draft_Rotate, Draft_Scale, Draft_Clone) still create objects at top level when the Copy box is checked.
OS: Ubuntu 22.04 LTS (XFCE/xubuntu)
Version: 0.21.30018 (Git)
Build type: Unknown
Hash: d68736537e1c0109fdc6c1f7449fd3a43ae4adb6
Python 3.10.4, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: French/France (fr_FR)
- Flachy Joe -
heron
Re: [Bug?] Draft transformations with Copy don't take care of Std_Part
Post by heron »
This seems to be its normal behaviour. Maybe would may to open a github issue to change it if there is no one yet.
I believe that this thread may be interesting to Roy. @Roy_043 What do you think?
Greetings.
Roy_043
Post by Roy_043 »
When copying an existing object you may also want to look at the Std_Group/Std_Part the original object is nested in. I am not sure what the most logical behavior is then.
FYI: When an object is copied with a Draft command, the new object is currently placed in the same layer (which is in fact a group) as the original.
