Question on Involute Gear Generation
WESIII
Post by WESIII »
Does the FreeCAD Involute Gear generator module/model include a factor for Gear Backlash, or alternatively, does it assume/calculate a "perfect" mesh?
Re: Question on Involute Gear Generation
Hi and welcome to the forum!
These are the properties you can set for a gear:
Bildschirmfoto 2022-08-12 um 18.21.06.png (138.93 KiB) Viewed 394 times
WESIII
Post by WESIII »
I am not seeing all those options in the data window. Thought it might be using Version 0.19, so I installed 0.20 after uninstalling 0.19.
How do I find/modify those additional options?
Screen Shot 08-12-22 at 02.24 PM.JPG (166.51 KiB) Viewed 354 times
WESIII wrote: Fri Aug 12, 2022 6:25 pm I am not seeing all those options in the data window. Thought it might be using Version 0.19, so I installed 0.20 after uninstalling 0.19.
You should rather/also update the Gears workbench. I have these versions
OS: macOS 10.16
Version: 0.21.29997 (Git)
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.3.51
  * sheetmetal 0.2.56
  * ExplodedAssembly
  * Curves 0.5.4
