For example, the properties panel has a 'Base' section.
In Russian it is translated as Основание . This is a wrong translation. Основные will be correct.
But if you type the word Основание into the Crowdin string translation search you won't find anything.
Because the word Base is popular and is present in many workbenches and it is duplicated. All translations of the world are blocked.
Many translators in Crowding probably have never opened FreeCAD and do not even know where translated word is located.
After that, incorrect translations appear that cannot be corrected.
In the admin Crowdin control panel there is an item display duplicates !!! I do not know what this will lead to !!! But I think this need to fix it.
The problem of existing strings in Crowdin that cannot be fixed
- Error.png (13.25 KiB) Viewed 608 times
Re: The problem of existing strings in Crowdin that cannot be fixed
I think that this post will be more useful if posted in "developer corner":Evgeniy wrote: ↑Tue Aug 16, 2022 1:24 pm For example, the properties panel has a 'Base' section.
https://forum.freecadweb.org/viewforum. ... 6d5d6a0b5a
Recently "Open Discussion" has became very populated by "strange discussion" and some other annoying things, that some developers don't check this place (@sliptonic is one of them, but I think he is not involved in translations).
Regards
Carlo D.
- Various other stuffs.
Translated Property Group Name "Base" https://forum.freecadweb.org/viewtopic.php?f=8&t=69413
https://github.com/FreeCAD/FreeCAD/blob ... #L111-L115
<message>
<location filename="../propertyeditor/PropertyModel.cpp" line="250"/>
<source>Base</source>
<translation>Основание</translation>
</message>
The only 'Base' I found in crowdin exists in Robot.tsvm4dim wrote: ↑Tue Aug 16, 2022 5:02 pm Translated Property Group Name "Base" https://forum.freecadweb.org/viewtopic.php?f=8&t=69413
- Base.PNG (49 KiB) Viewed 496 times
Thanks. Translator rights needs...vm4dim wrote: ↑Tue Aug 16, 2022 7:41 pm Hidden words in Crowdin - https://forum.freecadweb.org/viewtopic.php?f=8&t=69366
