Hello,
I just realized that the two thing do more or less the same thing, it's really just a matter of what you select. Two points --> Constrain coincident, Point and something else --> Constrain Point onto object.
Is there a reason why the two things shouldn't be put together?
[Sketcher] Putting Constrain coincident and Constrain Point onto Object together?
- pathfinder
Re: [Sketcher] Putting Constrain coincident and Constrain Point onto Object together?
There's already a discussion going about this somewhere. Sorry I don't have it ready at hand right now.
Please try to search previous topics before posting.
- adrianinsaval
https://forum.freecadweb.org/viewtopic.php?f=8&t=71793 and there was another thread in the past that also got messy, linked more than once there I think. Openbrain made a PR for combining these constraints but might have lost interest on the subject: https://github.com/FreeCAD/FreeCAD/pull/7478
Give it a try with using just one (either) of these "more or less the same thing", and report back.pathfinder wrote: ↑Mon Sep 26, 2022 9:23 pm I just realized that the two thing do more or less the same thing
If they are really the same thing then either should work for all your needs.
Gene
- pathfinder
I'll move it there then.adrianinsaval wrote: ↑Mon Sep 26, 2022 9:50 pm https://forum.freecadweb.org/viewtopic.php?f=8&t=71793 and there was another thread in the past that also got messy, linked more than once there I think. Openbrain made a PR for combining these constraints but might have lost interest on the subject: https://github.com/FreeCAD/FreeCAD/pull/7478
Yeah okay, that was bad phrasing on my part. What I meant to say was that they are similar enough that you can put them together. Kinda like the radius and diameter thing. Make it a drop down and add an autodetect option.
