[Feature Request] STEP export compound merge
NewJoker
Post by NewJoker »
whenever I export a model which consists of multiple faces/volumes that are fused with Part boolean operations (like Part Fuse) to STEP, I still get multiple entities after importing to another software (I tried with various programs). It would be great to have an option that could truly merge entities for export to STEP so that they would be recognized as individual object after importing to other software.
I attached an exemplary file. Even though it's fused, exporting it to STEP and importing to other CAD or CAE programs results in separate face objects. The same happens with solid models.
Step export compound.FCStd
(8.72 KiB) Downloaded 12 times
easyw-fc
Re: [Feature Request] STEP export compound merge
Post by easyw-fc »
NewJoker wrote: Fri Nov 18, 2022 9:51 pm Hi,
simply convert your fusion to solid (with Part https://wiki.freecadweb.org/Part_MakeSolid )
then your step file would be a single merged object
Step export compound-solid.FCStd
(10.42 KiB) Downloaded 9 times
Step export compound-Fusion (Solid).step
(7.29 KiB) Downloaded 8 times
NewJoker
Post by NewJoker »
easyw-fc wrote: Sat Nov 19, 2022 8:44 am simply convert your fusion to solid (with Part https://wiki.freecadweb.org/Part_MakeSolid )
Thank you very much, I didn't realize that this tool can do it. However, this works with surfaces but doesn't work with solids. Sometimes I want to merge assemblies into a single part, like in the attached example where Part Fuse still results in multiple parts after exporting to STEP.
Step merging solid 2.FCStd
(152.26 KiB) Downloaded 9 times
easyw-fc
Post by easyw-fc »
only when an object is a watertight solid the union can result in a single object... Otherways you will get a compound of detached objects
EDIT:
see here in 3d printing
https://danieltal.com/is-your-3d-print- ... ht-part-1/
search also for "manifold"
NewJoker
Post by NewJoker »
easyw-fc wrote: Sat Nov 19, 2022 12:55 pm only when an object is a watertight solid the union can result in a single object... Otherways you will get a compound of detached objects
In my case, the geometry should be watertight since I'm creating compounds out of valid solid parts placed on each other. Unless there's some issue with the accuracy of adherence of curved surfaces.
easyw-fc
Post by easyw-fc »
NewJoker wrote: Sun Nov 20, 2022 5:31 pm In my case, the geometry should be watertight since I'm creating compounds out of valid solid parts placed on each other. Unless there's some issue with the accuracy of adherence of curved surfaces.
in your case the issue is because of co-planar surfaces (an issue on OCC)
https://wiki.freecadweb.org/Part_Boolean (look for 'Coplanar problems')
you may workaround it with a small co-penetration between objects
(probably the best option because you generate your parts with code)
or using fuzzy fusion
https://dev.opencascade.org/content/fuz ... operations
you can use it (or get some code tips) with Defeaturing WB 'fuzzy union' command (and play with fuzzy tolerance)
Step merging solid fuzzy.FCStd
(222.47 KiB) Downloaded 7 times
Step merging solid fuzzy-UnionFuzzy.step
(117.66 KiB) Downloaded 4 times
adrianinsaval
Post by adrianinsaval »
easyw-fc wrote: Mon Nov 21, 2022 9:37 am or using fuzzy fusion
That's very interesting, would be nice if it was possible to control this property on regular BOP in FreeCAD.
easyw-fc
Post by easyw-fc »
there is an old thread
https://forum.freecadweb.org/viewtopic. ... b&start=10
and a detailed surwey
https://github.com/realthunder/FreeCAD_ ... issues/235
Fuzzy union/common can be used only through python code ATM
there is also an open issue
https://github.com/FreeCAD/FreeCAD/issues/5612
NewJoker
Post by NewJoker »
@easyw-fc Thank you for the information, I didn't know that there are such fuzzy boolean operations available in one of the add-on modules. It would be great to have them implemented in Part workbench.
drmacro
Post by drmacro »
NewJoker wrote: Tue Nov 22, 2022 9:56 am @easyw-fc Thank you for the information, I didn't know that there are such fuzzy boolean operations available in one of the add-on modules. It would be great to have them implemented in Part workbench.
Use Edit>Customize to add to as many toolbars as you desire. ;)
