[Solved] PartDesign: Pad Up to Face with Custom direction
flachyjoe
Post by flachyjoe »
This combination of PartDesign_Pad options cause an error:
Capture d’écran_2022-11-21_13-14-08.png (44.76 KiB) Viewed 1448 times
BrokenPad.FCStd
(14.73 KiB) Downloaded 27 times
Selected limit is the box up face.
OS: Ubuntu 22.04.1 LTS (XFCE/xubuntu)
Version: 0.21.31068 (Git)
Build type: Unknown
Hash: 186ed6e6198331ec7467844007a1074eb40989b3
Python 3.10.6, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: French/France (fr_FR)
- Flachy Joe -
flachyjoe
Re: PartDesign: Pad Up to Face with Custom direction
Post by flachyjoe »
Bump !
Is it a known bug ? Can I open a github issue :?:
- Flachy Joe -
adrianinsaval
Post by adrianinsaval »
flachyjoe wrote: Thu Nov 24, 2022 3:43 pm Can I open a github issue :?:
Go ahead, there's no requirement to post in the forum anymore (that being said please don't unnecessarily pollute the issue tracker either)
I guess it is an OCC issue, where the FreeCAD developers cannot do much. A ticket is sensible, so it can be checked when a new OCC version comes out.
flachyjoe
Post by flachyjoe »
@chrisb it doesn't come from OCC, the check didn't take care of the direction of extrusion :
https://github.com/FreeCAD/FreeCAD/blob ... d.cpp#L525
    // Check that the upToFace does not intersect the sketch face and
    // is not parallel to the extrusion direction (for simplicity, supportface is used instead of sketchshape)
    BRepAdaptor_Surface adapt1(TopoDS::Face(supportface));
    BRepAdaptor_Surface adapt2(TopoDS::Face(upToFace));
    if (adapt2.GetType() == GeomAbs_Plane) {
        if (adapt1.Plane().Axis().IsNormal(adapt2.Plane().Axis(), Precision::Confusion()))
            throw Base::ValueError("SketchBased: Up to face: Must not be parallel to extrusion direction!");
Fixed with https://github.com/FreeCAD/FreeCAD/pull/7879
- Flachy Joe -
flachyjoe wrote: Fri Nov 25, 2022 8:54 pm @chrisb it doesn't come from OCC,
Black friday for my guessing rate :evil: .
flachyjoe
Post by flachyjoe »
chrisb wrote: Fri Nov 25, 2022 9:36 pm Black friday for my guessing rate :evil: .
You're welcome, without your reflection I maybe didn't look the code ;)
- Flachy Joe -
uwestoehr
Post by uwestoehr »
flachyjoe wrote: Fri Nov 25, 2022 8:54 pm Fixed with https://github.com/FreeCAD/FreeCAD/pull/7879
Thanks. However this PR deletes too much. The check that the distance between the sketch and the face must stay. The error message is however wrong.
Also since the face "adapt1" is no longer necessary, the face "adapt2" must be renamed.
While testing I also found another bug: the Reverse checkbox has no effect on "upToFace" and must therefore be disabled.
I will have a look.
flachyjoe
Post by flachyjoe »
Hi @uwestoehr ,
uwestoehr wrote: Fri Dec 02, 2022 6:37 pm The check that the distance between the sketch and the face must stay.
I'm not sure: in the case I described the distance is null but the pad can be done.
- Flachy Joe -
adrianinsaval
uwestoehr wrote: Fri Dec 02, 2022 6:37 pm While testing I also found another bug: the Reverse checkbox has no effect on "upToFace" and must therefore be disabled.
No I think we had enabled this on purpose before after we found it was sometimes needed, it's important when the face could be a limit on both sides of the profile, see this example, the pad gos up to the inner cylinder face and can be reversed.
Can you maybe add a comment in the code or even better a test script so that this isn't changed in the future by someone else? I can see how one can easily think this option doesn't make sense there.
upToFaceREverseExample.FCStd
(26.07 KiB) Downloaded 22 times
