[BUG #7872]: Cutting features "up to face" create traces and multiple faces
Piero69
Post by Piero69 »
i noticed that features with option "up to face" are not refined at all, they create traces and multiple faces on body. Following refining and recalculation do nothing.
in the attached example a pocket with made with 25mm depth looks good, the same one "up to face" creates traces and mulptiple faces.. this should not be the intent of feature
up to face.jpg (176.74 KiB) Viewed 807 times
feature up to face.jpg (181.22 KiB) Viewed 814 times
feature with by dimension.jpg (178.45 KiB) Viewed 814 times
Re: [BUG]: Cutting features "up to face" create traces and multiple faces
Set Refine=true for the pocket. This removes the additional seams - which usually do no harm, and only have to be removed for some filleting operations.
Piero69
Post by Piero69 »
chrisb wrote: Wed Nov 23, 2022 7:59 am Set Refine=true for the pocket. This removes the additional seams - which usually do no harm, and only have to be removed for some filleting operations.
it's set to true (see attachment), but refine doesn't look like working. that's why i named [BUG] in the post
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.31058 (Git)
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Italian/Italy (it_IT)
Installed mods:
  * 3DfindIT 1.2.0
  * A2plus 0.4.54b
  * Assembly3 0.11.4
  * Assembly4 0.11.8
  * Behave-Dark-Colors 0.1.1
  * BOLTSFC
  * CurvedShapes 1.0.4
  * Curves 0.6.1
  * dxf_library
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners
  * FCGear
  * freecad.gears 1.0.0
  * ImportNURBS
  * InventorLoader 1.3.0
  * InventorLoader.backup1663313199.3655012
  * invgears 0.1.2
  * lattice2
  * nurbs
  * Render 2022.1.0
  * sheetmetal 0.2.59
  * sheetmetal.backup1663313192.0420823
  * Silk -774766024.0.0
  * symbols_library
refine true.jpg (210.96 KiB) Viewed 735 times
Piero69
Post by Piero69 »
@chrisb
only if we have a following feature the refining works, otherwise it doesn't and also an exported step is multi-faces and traced (see attachments)
This is not correct, if for many reasons my feature is compulsory the last in a model i get an incorrect outcome.
what do you think?
Installed mods:
  * 3DfindIT 1.2.0
  * A2plus 0.4.54b
  * Assembly3 0.11.4
  * Assembly4 0.11.8
  * BOLTSFC
  * Curves 0.6.1
  * dxf_library
  * ExplodedAssembly
  * fasteners
  * FCGear
  * ImportNURBS
  * invgears 0.1.2
  * lattice2
  * nurbs
  * Render 2022.1.0
  * sheetmetal 0.2.59
  * symbols_library
refine up to face.stp
(29.86 KiB) Downloaded 19 times
refine up to face.FCStd
(18.17 KiB) Downloaded 19 times
The problem seems to be the revolution. If you hover over the bottom, you see that it is not flat in XY-plane.
Piero69
Post by Piero69 »
chrisb wrote: Wed Nov 23, 2022 12:59 pm The problem seems to be the revolution. If you hover over the bottom, you see that it is not flat in XY-plane.
is it a bug in revolution feature?
Piero69
Post by Piero69 »
@chrisb
the problem occurs also working by pad feature instead of revolution, maybe it's not a problem of revolution
up to face 2.FCStd
(18.72 KiB) Downloaded 21 times
up to face 2.jpg (178.85 KiB) Viewed 655 times
I have seen this before, but not for things in XY plane, so I guessed it was due to rounding/precision issues. It's a pity that up-to-first doesn't work here, because that would also be stable with respect to toponaming issues.
Re: [BUG #7872]: Cutting features "up to face" create traces and multiple faces
Post by Kunda1 »
