[Solved] [CSG Import] <Exception> MultiFusion failed
Knochi
Post by Knochi »
i made a beautiful model of an SMD LED in openSCAD and wanted to use KicadStepup Workbench to convert it into a 3D model for KiCAD EDA.
Steps to reproduce:
  1. create model with freecad
  2. export as csg
  3. install FreeCad via flatpak (Discovery)
  4. open FreeCad
  5. new document
  6. open file..
  7. select .csg previously exported
Report View:
12:04:18  WARNING: Token 'DOT' defined, but not used
12:04:18  WARNING: Token 'WORD' defined, but not used
12:04:18  WARNING: There are 2 unused tokens
12:04:18  <Exception> MultiFusion failed
12:04:18  Recompute failed! Please check report view.
12:04:18  <Exception> Input shape is null
12:04:18  End processing CSG file
Version Info:
OS: KDE Flatpak runtime (KDE/plasma-steamos-oneshot)
Version: 0.20.1.29410 (Git)
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.9.9, Qt 5.15.5, Coin 4.0.0, Vtk 8.2.0, OCC 7.6.2
Locale: English/Germany (en_DE)
Installed mods:
  * kicadStepUpMod 10.16.5
The attachment SideLED_freeCADrender_221201_DNK.png is no longer available
The attachment SideLED_openSCADrender_221201_DNK.png is no longer available
I narrowed down the problem to the "cap()" module:
module cap(){
    translate([-capWidth/2,0,bodyDims.z/2]) difference(){
      cube([capWidth,bodyDims.y,bodyDims.z],true);
      for (iy=[-1,1])
        translate([capWidth/2,iy*bodyDims.y/2]) circle(filRad);
      cube([capWidth+fudge,bodyDims.y-filRad*2-plating*2,bodyDims.z-plating*2],true);
      translate([-(capWidth-(capWidth-filRad-plating)+fudge)/2,0,0])
        cube([capWidth-filRad-plating+fudge,bodyDims.y+fudge,bodyDims.z-plating*2],true);
freeCad screenshot
freeCad screenshot
The issue seems to be in the for loop that gets substracted
for (iy=[-1,1])
[edit] ok seems like actually the circle is the problem. Even one circle, without the for loop, don't work.
without that it renders in FreeCad
openSCAD screenshot
openSCAD screenshot
Re: [CSG Import] <Exception> MultiFusion failed
Post by Kunda1 »
Knochi
Post by Knochi »
You can close this thread... tried to substract a circle (2D) from an cube(3D) :lol:
openSCAD didn't produce a warning but when i use cylinder() instead it works.
Re: [Solved] [CSG Import] <Exception> MultiFusion failed
Post by Kunda1 »
Marked it [Solved] ;)
keithsloan52
Post by keithsloan52 »
Knochi wrote: Thu Dec 01, 2022 12:10 pm You can close this thread... tried to substract a circle (2D) from an cube(3D) :lol:
So to clarify Native OpenSCAD did nor barf
did it correctly render?
Did it use a Sphere instead or a circle?
Does it do likewise for a square?
Does it also work the other way does it use a circle when subtracting a sphere from a square?
The FC OpenSCAD importer relies on having a valid CSG file.
If OpenSCAD is handling this as a special case i.e. using a Sphere for a circle when mixing 2D and 3D operations
then it would not be to hard to add this to the importer.
@chennes
