AttachmentOffset question, why not 3 rotation angles?
This is all as clear as mud to me. To make a complex rotation don't we need 3 rotation angles for an attachment Offset:
Rotate X as this angle =
Rotate Y as this angle =
Rotate Z as this angle =
Currently we have one angle to share with 3 axis.
Thanks for your time if you have the time.
Re: AttachmentOffet question, why not 3 rotation angles?
It's a mathematical theorem, that any sequence of rotations in space can be replaced by a single rotation around a certain axis.
While having the championship in Qatar: As a corollary to that theorem it can be said that there are always two moments in each football game where two points of the ball are in the same places.
Edit: OK now I get it.
So if I want to input this data:
Rotation angle X = xxx
Rotation angle Y = xxx
Rotation angle Z = xxx
into an Attachment offset, how would I do those calculations. Are there standard calls for this?
Thanks
Thanks
Let FreeCAD do it for you, by using the Placement Dialog.
- Shalmeneser
At least a good news.
I needed to replicate the AttachmentOffset concept so I made a rotation like this (pic). If there is ever a redesign of the properties panel something like this would make more since IMO. I would imagine the properties panel was designed this way as a proof of rotation during develoment so maybe if we had a switch to make the panels a bit more friendly.
Thanks
Thanks
- Attach1.png (21.84 KiB) Viewed 666 times
I can only guess at what Rotation your dialog represents. What rotations, in what order, around what axes does it describe?
I do know what Euler angles are, but they are only useful in rather specialized situations - like in rigid body dynamics.
The Placement Dialog also offers the often underrated incremental mode, where you can turn an object one by one around the axes.
Here are the controls from my PDA (PartDesign Assy). The pin has been attached to the top of the hex by assembly (sketch highlighted) so there is no need for X or Y controls, but the Z and Rotation are useful. I really like the scroll capabilities of the input fields using the double spin box, you hover and use the scroll wheel to see changes in real time. By using the Select as Body option I can click on any object and get the body selection. I think it's too easy to modify the assembly, I will need to add a lock of some kind.
I use a copy of the targeted sketch AttachmentOffset to make all the changes, then apply this to the Body Placement. I store the entered data in added properties.
With some mods this could be a second generation Transform tool.
- GIF rotate.gif (850.02 KiB) Viewed 552 times
