Release discussion 0.15
quick61
Re: Release discussion 0.15
Postby quick61 » Fri Apr 10, 2015 4:52 pm
Sourceforge.net still has the "Looking for the latest version?" link pointing to version 0.14 for windows and Mac.
Mark
NormandC
Postby NormandC » Fri Apr 10, 2015 7:00 pm
Not for me, it's showing 0.15.4671 on Windows 7. You need to use the OS to be shown the choice.
yorik
Site Admin
Postby yorik » Fri Apr 10, 2015 7:08 pm
We need to upload the source package... I'll take Norm's one from the PPA
NormandC
Postby NormandC » Fri Apr 10, 2015 8:05 pm
Please don't! :D
I messed the Version.h file because I checked out the remote branch.
shoogen
Postby shoogen » Fri Apr 10, 2015 8:07 pm
And please check the Version.h file manually for the repo URL and version number(ing scheme) as well.
yorik
Site Admin
Postby yorik » Fri Apr 10, 2015 8:09 pm
Ok... I'll update!
NormandC
Postby NormandC » Sat Apr 11, 2015 3:30 pm
Hi Yorik,
I'm guessing you have not updated the tarball yet? Because its Version.h is identical to mine. The problem is with the FCRepositoryBranch.
// Version Number
#define FCVersionMajor "0"
#define FCVersionMinor "15"
#define FCVersionName  "Vulcan"
// test: $Format:Hash (%H), Date: %ci$
#define FCRevision      "4671 (Git)"      //Highest committed revision number
#define FCRevisionDate  "2015/04/05 17:25:02"     //Date of highest committed revision
#define FCRepositoryURL "git://git.code.sf.net/p/free-cad/code"      //Repository URL of the working copy
// Git relevant stuff
#define FCRepositoryHash   "244b3aef360841646cbfe80a1b225c8b39c8380c"
#define FCRepositoryBranch "(détaché de origin/releases/FreeCAD-0-15)"
You can see how it come out in this topic: viewtopic.php?f=3&t=10495
Newbie question: rather than figuring out how to create a local branch from the remote, then regenerate the Version.h file then making a new tarball, can I simply edit the silly file manually then make the new tarball??? :roll:
yorik
Site Admin
Postby yorik » Sat Apr 11, 2015 4:57 pm
Oops sorry, I ended up forgetting (sourceforge kept disconnecting yesterday, for a change)... I've fixed the Version.h and am uploading it again now.
Basically I extracted the archive (tar -xaf freeecad-xxxx.tar.gz), then edited the src/Build/Version.h manually (simply removed the "détaché" text, left the origin/releases/FreeCAD-0.15), then recompressed the extracted folder (tar -zcvf freecad-xxxx.tar.gz foldername)
NormandC
Postby NormandC » Sat Apr 11, 2015 4:58 pm
Edit: I'm too late apparently :D
Still, I've got a DFSG tarball we should probably upload too.
Okay, I finally retrieved my "git cheatsheet" and remade the tarball properly. :roll:
cd freecad-code
git branch --t releases/FreeCAD-0-15 remotes/origin/releases/FreeCAD-0-15
git checkout releases/FreeCAD-0-15
cd ..
mkdir freecad-releases-0-15-build
cd freecad-releases-0-15-build
cmake ../freecad-code
make dist-git
make distdfsg-git
I have two tarballs: freecad-0.15.4671.tar.gz and freecad-0.15.4671-dfsg.tar.gz. (Dropbox links)
Or if you give me write access to Sourceforge I can upload them.
yorik
Site Admin
Postby yorik » Sat Apr 11, 2015 5:22 pm
Good idea... I added you as a "developer" to the sourceforge project which - I think - should give you the right to add files. Please check if it works, not sure anymore if this is the correct way...
