Release discussion 0.15
shoogen
Re: Release discussion 0.15
Postby shoogen » Sat Jan 24, 2015 12:56 pm
I think we have to talk about issue #1852
I assume that you will not rename the python exceptions in the foreseeable future.
IMHO issue #1926 an OCCT bug , unfixable from FreeCAD perspective.
Reason: removed the word "workaround"
Site Admin
Postby wmayer » Sat Jan 24, 2015 1:47 pm
Not for the release.This can be done later at any time.
yorik
Site Admin
Postby yorik » Sat Jan 24, 2015 4:17 pm
I don't think we should care too much about these issues... After all, all projects make releases with some bugs unfixed... And AFAICS none is really critical in the sense that it prevents you from using FreeCAD. We could maybe make a list of the most annoying ones and notify about them in the release notes
Site Admin
Postby wmayer » Sat Jan 24, 2015 5:02 pm
But the severity should be adjusted then. 1676 and 1776 can be downgraded to 'major'. 1647 should be rechecked. 1831 can stay but this isn't something that can be fixed any time soon.
shoogen
Postby shoogen » Sun Jan 25, 2015 1:38 pm
Is this just a branding issue? Like the base execption should be called "FancyCAD.Base.AppError" instead of "FancyCAD.Base.FreeCADError"
jreinhardt
Postby jreinhardt » Tue Feb 10, 2015 11:25 am
wmayer wrote: So, what do you think about a feature freeze for end of January? Then after a test phase of a few weeks we can do the final release in end of February.
So it would make sense to brush up the translations now, wouldn't it. If I read the crowdin logs correctly, yorik has uploaded strings already two weeks ago.
The Finns and Braziliens are already done. But then there are quite a few languages in the seventy and eighty percent regions that might be able to fully catch up, I will list them here for publicity:
Chinese Traditional: 77%
Czech: 70%
English: 81% (I don't understand that one)
French: 91%
German: 81%
Italian: 80%
Japanese: 87%
Polish: 81%
Portuguese: 79%
Romanian: 71%
Russian: 74%
Spanish: 92%
So if you speak any of these languages, get going! Translations are done on crowdin (registration required):
https://crowdin.com/project/freecad
BOLTS, standard parts library for FreeCAD Thread, Help with Translation
yorik
Site Admin
Postby yorik » Tue Feb 10, 2015 3:26 pm
I'll post about this on FB and G+ too...
shoogen
Postby shoogen » Tue Feb 10, 2015 3:27 pm
I got a pull request solely for the release branch.
git://github.com/5263/FreeCAD bugfix-drawingarcs
as discussed at viewtopic.php?f=3&t=9670&p=78516#p78483
shoogen
Postby shoogen » Tue Feb 17, 2015 2:34 pm
Yorik,
I've got another trivial branch lying around. I suppose that I's possible to open a file with Draft Elements without loading the full Draft Workbench and thous not registering the GUI commands. I would suggest to integrate in the 0.15 release since it doesn't harm if DraftTools was imported before.
diff --git a/src/Mod/Draft/Draft.py b/src/Mod/Draft/Draft.py
index 68cb516..e54343a 100644
--- a/src/Mod/Draft/Draft.py
+++ b/src/Mod/Draft/Draft.py
@@ -3198,6 +3198,7 @@ class _ViewProviderDraft:
         return
     def setEdit(self,vobj,mode=0):
+        import DraftTools
         FreeCADGui.runCommand("Draft_Edit")
         return True
Site Admin
Postby wmayer » Tue Feb 17, 2015 4:02 pm
Not sure what this is supposed to fix but when I e.g. import a dxf file while I am in PartDesign there always appear the "Draft tray" toolbar which is slightly annoying. With your change this toolbar still appears.
