Hello as I register with the forum?
I can only register on sourceforge.net
Tanks
¿Hola como me registro en el foro?
Solo me puedo registrar en sourceforge.net
Gracias
How do I register?
Re: How do I register?
You have to register on Sourceforge and will be automatically registered on this forum here.
ok, but when I post in the forum appear as guest, and I put up a Username field: should I choose me to not put me as a guest. I'm on login to sourceforge.net
thanks for your time
In spansih
ok, pero cuando publico en el foro aparezco como invitado, y arriba me pone un campo Username: que debo elegir yo para que no me ponga como invitado. Estoy en login a sourceforge.net
gracias por el tiempo dedicado
In spansih
Sometimes the Sourceforge system has some bugs, and you appear as "not logged" on the forum even if you are logged on sourceforge... You must logout/login again to solve, if I remember correctly...
If that was the error.
And works well.
Thank you very much
In spanish
Si, ese era el error.
Ya funciona bien.
Muchas gracias
And works well.
Thank you very much
In spanish
Ya funciona bien.
Muchas gracias
