Unofficial Window X64 and X32 Development Snapshots
sgrogan
Re: Unofficial Window X64 and X32 Development Snapshots
Postby sgrogan » Fri Jan 02, 2015 5:23 pm
ProBowlUk wrote:Can you give me the files needed to run the best version of FreeCAD for Windows ?
Will I need Visual C Redist ? ( for some reason x64 failed, but x84 is loaded.[/i )
Your OS is 32 bit so x64 will not work, you need to use x86 version
Open the bin folder of the extracted .7z file and start FreeCAD by double clicking the FreeCAD Icon
"fight the good fight"
ProBowlUk
Postby ProBowlUk » Fri Jan 02, 2015 5:24 pm
Thanks for the quick reply ...
doesn't appear to say which of the files to use on my system :mrgreen:
ProBowlUk
Postby ProBowlUk » Fri Jan 02, 2015 6:03 pm
Is there a ReadMe file on how to install ?
Or is it simply a matter of making a copy of FC14, renaming it "15", and then
copying the files in the .7z folders to overwrite existing ones ?
cheers
saso
Postby saso » Fri Jan 02, 2015 6:34 pm
please note, this are development test builds. you should be able to run them by simply extracting the archive (7z) and run the FreeCAD.exe inside the bin folder. there is no install. you don't have to copy it (the extracted folders and files) to any special place, you can keep it on the desktop if you like. you don't have to replace your existing FreeCAD installation. just extract and run. you remove (uninstall) it by simply deleting the folder.
sgrogan
Postby sgrogan » Fri Jan 02, 2015 6:52 pm
Thanks saso,
I think your explanation is more clear than mine.
I will update the Wiki and Peterl94 will upload a readme to the Win dev directory. I am glad to see people using the dev builds :D
saso
Postby saso » Fri Jan 02, 2015 6:59 pm
i guess one thing to note with this is that it uses the same config directory and files as the original (installed) version. so in some cases this could result in some unexpected changes and confusion or worst case corrupt config files. in most cases this should not represent a big problem and should be possible to solve by simply deleting the config files to "reset" them. but for those users to whom their personal configuration is critical it would be advised to keep a copy.
TT-RS
Postby TT-RS » Fri Jan 02, 2015 10:01 pm
saso wrote:i guess one thing to note with this is that it uses the same config directory and files as the original (installed) version. so in some cases this could result in some unexpected changes and confusion or worst case corrupt config files. in most cases this should not represent a big problem and should be possible to solve by simply deleting the config files to "reset" them. but for those users to whom their personal configuration is critical it would be advised to keep a copy.
I agree with this, however for me this not a big problem.
r-frank
Postby r-frank » Sat Jan 03, 2015 3:27 pm
Hello.
I was not quite sure where to post it, but i am having graphical issues with the dev snapshot on win 7 64 bit.
See here.
I didn't follow all the discussion about the qaurter based viewer.
But i just verified that 0.14.3700 does work perfectly and 0.15.4332 does not.
So it looks like a graphical issue and/or something lib-related (just my personal guess ...).
Could you take a look ?
Thanks in advance.
Roland
My GrabCAD FreeCAD-Projects
ProBowlUk
Postby ProBowlUk » Mon Jan 05, 2015 1:46 am
Hi
Is this a known problem ?
COMODO Internet Protection ___ Malware Detection ___ has just reported that ...
FreeCAD\\bin\Lib\site-packages\numpy\core\test_rational_d.pyd
contains Malware@#185ztkk94g3t3
ektus
Postby ektus » Mon Jan 05, 2015 8:36 am
saso wrote:please note, this are development test builds. you should be able to run them by simply extracting the archive (7z) and run the FreeCAD.exe inside the bin folder. there is no install. you don't have to copy it (the extracted folders and files) to any special place, you can keep it on the desktop if you like. you don't have to replace your existing FreeCAD installation. just extract and run.
In my case, it doesn't work this way as has been discussed earlier in this thread. I tried it again today with the version below, still the same problem. The errors go away and the self test completes without errors if I rename the "FreeCAD 0.14" folder inside "Program Files", create a new folder with that same name there and place the three main folders from the dev snapshot inside. The 3D mouse still doesn't work, though.
Regards
Ektus.
OS: Windows 7
Version: 0.15.4346 (Git)
Hash: e329cb5c3acd5b170359e0e8cd28d98b61be935d
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
