Interlocking modules
execuc
Postby execuc » Sat Apr 13, 2019 9:15 pm
Hello,
My name is Alexandre and I my hobbies are arduino, PCB, 3D printing, laser cut...
I use FreeCAD since several years to make enclosure for my electronic projects but I don't use 3D printing to do it because it takes time to print except for small parts.
I prefer to use laser cutting which is faster and allows to make larger boxes.
In order to make my work easier, I have developed a module for Freecad that allows to create connections between parts from Part/PartDesign workshops. Then, an export tool projects parts on a 2D plan in order to save outlines as Flattened SVG. SVG file is then reworked on Inkscape before being sent in cutting.
An example : Image
Module manages connection of type tab/slots, T-slot joints and crosspiece. It also allows to create rounded corner with living hinges.
Python source code and documentation is on GitHub : https://github.com/execuc/LCInterlocking
If this module corresponds to the freecad philosophy, I would like to propose it as an addon via the FreeCAD addon manager. So do not hesitate to say what you think about it.
Thank you
Re: Interlocking modules
Postby Kunda1 » Sat Apr 13, 2019 10:54 pm
An example : Image
Try using this url instead:
[img]https://github.com/execuc/LCInterlocking/blob/master/docs/imgs/illustration.png?raw=true[/img]
Postby NormandC » Sat Apr 13, 2019 11:13 pm
Hello execuc,
Welcome to the forum - impressive first post!!!
I want to thank you for your very detailed documentation with links to separate command pages.
I will try to dedicate some time to test this, I'm particularly interested in your statement that it can work with PartDesign bodies. :)
reox
Postby reox » Sun Apr 14, 2019 11:47 am
Nice! I fell in love with this tool from the videos I saw but unfortunately I never got this working ... I'll check it out for sure :)
execuc
Postby execuc » Mon Apr 15, 2019 6:59 am
Thanks Kunda1, I have modified the image link, it works.
In January 2019, I changed HMI a little and the videos are out of date but the principle remains the same. I will do videos again when I could.
I did a short documentation because I agree that the interface is only intuitive for me :)
Do not hesitate to create issues when it does not work, because the module is not very robust when (ie: with non-rectangular parts...).
triplus
Postby triplus » Mon Apr 15, 2019 7:47 pm
Thanks for creating the Interlocking module and for sharing it.
P.S. Such features are more and more requested by people. For not having to create everything manually, but to have a feature that adds a tab, slot, hole ... to selection.
execuc
Postby execuc » Mon Apr 15, 2019 8:50 pm
Thank you! I have just created a pull request to add it in addons manager.
