[finally released] FreeCAD 0.19 Windows installer release candidate
turn211
Re: [finally released] FreeCAD 0.19 Windows installer release candidate
Postby turn211 » Fri Apr 02, 2021 10:43 pm
uwestoehr wrote:
Fri Apr 02, 2021 9:54 pm
bug on all Pre Releases up to Version: 0.19.24267 (Git) which was QT 5.12.5
Confirmed. So the question is not if it is a Conda build or a LibPack build and since it occurs with Qt 5.12 and 5.15, it is most probably not Qt.
What was the last Windows build without the bug? Then I can do a bisect since it seems that a change in FreeCAD's code causes this.
I guess my previous post wasn't clear enough. ALL Windows builds up to Version: 0.19.24267 (Git) did not exhibit this bug. Side note: I design Stylesheets for other Qt 5.15 apps and they don't exhibit this bug. I don't think it is QT
Edit: Clarity
turn211
Postby turn211 » Fri Apr 02, 2021 10:51 pm
I stand corrected. The other apps i design Stylesheets for are using Qt 5.13.2
turn211
Postby turn211 » Fri Apr 02, 2021 11:02 pm
uwestoehr wrote:
Fri Apr 02, 2021 10:41 pm
:oops: It is Qt and only Qt 5.15.1:
https://bugreports.qt.io/browse/QTBUG-86587
and
https://bugreports.qt.io/browse/QTBUG-88276
The first one is fixed in 5.15.2 and I am trying now out if a Qt upgrade fixes our problem.
I tested styling QPushButtons without padding and they work so indeed it is a Qt bug
uwestoehr
Postby uwestoehr » Sat Apr 03, 2021 12:14 am
Yes, this fixes the bug. I'll now build a new installer that you can test.
@turn211, when you reply, please only cite the sentences you actually refer to. To edit your own post, don't reply to it but just edit it (the leftmost button at the upper right of a post)
chennes
Postby chennes » Sat Apr 03, 2021 12:17 am
That's great news -- I was a little worried it would turn out to be one of the things they fixed in (commercial-only) 5.15.3. Thanks for tracking it down!!
Chris Hennes
Pioneer Library System
uwestoehr
Postby uwestoehr » Sat Apr 03, 2021 3:48 am
Here it is: https://github.com/donovaly/FreeCADInst ... ller-1.exe
Please test and report back.
I named it FC 0.19.2 because this will deserve a new maintenance release to distinguish it from the other 0.19 releases. I assume more users will complain about the broken style sheets.
turn211
Postby turn211 » Sat Apr 03, 2021 5:11 am
Works perfect here. Bug gone. Could commit PR 4668 make it into this 19.2 maintenance release as it fixes a Qt 5.15 introduced Stylesheet bug.
Forum Discussion https://forum.freecadweb.org/viewtopic.php?f=34&t=56875
Thanks
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/Canada (en_CA)
uwestoehr
Postby uwestoehr » Sat Apr 03, 2021 5:02 pm
Very good that we fixed it that simple.
I asked Werner to commit the PR to the 0_19 branch.
Then we need to make a new release 0.19.2. @sgrogan, OK with you?
sgrogan
Postby sgrogan » Sat Apr 03, 2021 6:35 pm
Yes! This is how I'd prefer to handle these types of fixes. Your comment in the PR is spot on.
"fight the good fight"
uwestoehr
Postby uwestoehr » Wed Apr 07, 2021 2:07 pm
Fine. Werner committed the PR now also to the 0.19 branch:
https://github.com/FreeCAD/FreeCAD/comm ... 292a476672
So we can release 0.19.2 right now. Can you please make a tag and all the other steps that need to be done? I can help with a Win-installer if you like.
