[FreeCAD 0.20] a beta release for Windows is available
- adrianinsaval
Re: [FreeCAD 0.20] a beta release for Windows is available
looks like the dependencies added for addon manager were not added to the libpack
... trying to install the Beta_1 once and again, I also deleted the used
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds (looo's version)
Now I installed 20.27422 again => and this one runs as before.
OS: Windows 10 Version 2009
Version: 0.20.27422 (Git)
Hash: d938733eaf2c2ce7cb18d1cbb56147185c473530
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
I am having the same issue with the FreeCAD 0.20 Windows Beta release that hpbmo reported when trying to open Addon Manager.
Version: 0.20.28871 (Git)
Hash: 10fa08e87991f87ea714a7026a600800aa74888a
Python 3.8.10, Qt 5.15.3, Coin 4.0.1, OCC 7.5.3
- Report View.PNG (15.9 KiB) Viewed 2300 times
Thanks for testing! This is why I made the release.
I tried hard to update Qt but after 3 days I have to give up. I cannot find out what is wrong with Qt5Network nor fix it . All builds I made suffer the same issue, even Qt builds from other persons at GitHub. So we have to stay with Qt 5.15.2.
To proceed, here is a second build where the Qt5Network issue is fixed:
https://github.com/FreeCAD/FreeCAD-Bund ... /0.20beta1
Please give this a try and report back.
- MisterMaker
That last link the FreeCAD-0.20.0beta-WIN-x64-installer-2 doesn't want to boot on my windows 10 system. I only get a very short loading icon on my mouse and then nothing, no errors nothing happens.
Stupid windows trying to push their windows store by screwing up direct downloads from the internet under the false idea of security.
The installer gets blocked and windows wasn't telling me it did that. Seems like some sneaky windows update decided it needed to protect me from myself. I need to switch too linux....
If you right click the file you need to tag below option, it is in Dutch but it says it has been blocked.
Edit,Editie Windows 10 Pro
Versie 21H2
Installatiedatum 15-5-2021
Build van besturingssysteem 19044.1706
Ervaring Windows Feature Experience Pack 120.2212.4170.0
With the second build the AddonManager starts as usual
Version: 0.20.28886 (Git)
Hash: a564d5ced7aecf320a0ac2d73f824a3dc7861eb3
Locale: German/Switzerland (de_CH)
Installed mods:
* A2plus 0.4.56
* Assembly4 0.11.10
* CubeMenu
* Curves 0.4.2
* Defeaturing
* DynamicData 2.46.0
* ExplodedAssembly
* fasteners 0.3.40
* fcgear 1.0.0
* kicadStepUpMod 10.11.9
* Manipulator 1.4.3
* pluginloader
* sheetmetal 0.2.49
* Ship 2022.4.11
* ThreadProfile 1.81.0
... here it also works. Addon manager works.
During download and installation one must go through diverse Win10 rantings:
- MisterMaker
At least you got a message, mine was like nope not installing this.
Maybe we can do something like this, and please our M$ overlords.
https://github.com/mayrinck/FOSSonMicrosoftStore
Hopefully it will stop people from selling it. After seeing that Freecad is multiple times on the MS store for money I made a request here:
https://github.com/mayrinck/FOSSonMicro ... ussions/36
I checked if it was legit and he has 2 apps on the store one is DIA which is pretty nice program, and it is free.
https://www.microsoft.com/store/productId/9NPVGP9L96JJ
- MisterMaker
I was doing some path cnc stuff I broke Freecad. PAth won't load anymore and get an error on start:
Edit; I think it happened when I by accident deleted the geometry on which my home position was set. After removing all path features I could redo is and now it works again.
OS: Windows 10 (10.0)
Version: 0.20.28671 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
* Assembly3 0.11.2
* Behave-Dark-Colors 0.0.1
* FeedsAndSpeeds 0.3.0
* FEM_FrontISTR 0.1.0
* IconThemes
* lattice2 1.0.0
* Render 2022.1.0
* SelectorToolbar
* sheetmetal 0.2.49
* ToolbarStyle
14:28:34 During initialization the error "DLL load failed while importing _coin: Kan opgegeven procedure niet vinden." occurred in freecad.asm3
14:28:34 --------------------------------------------------------------------------------
14:28:34 Traceback (most recent call last):
File "<string>", line 217, in InitApplications
File "C:\Program Files\FreeCAD_0.20\bin\lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 843, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Users\marij\AppData\Roaming\FreeCAD\Mod\Assembly3\.\freecad\asm3\init_gui.py", line 3, in <module>
from . import gui
File "C:\Users\marij\AppData\Roaming\FreeCAD\Mod\Assembly3\.\freecad\asm3\gui.py", line 4, in <module>
from pivy import coin
File "C:\Program Files\FreeCAD_0.20\bin\lib\site-packages\pivy\__init__.py", line 30, in <module>
from .coin import SoDB, SoNodeKit, SoInteraction
File "C:\Program Files\FreeCAD_0.20\bin\lib\site-packages\pivy\coin.py", line 21, in <module>
from . import _coin
ImportError: DLL load failed while importing _coin: Kan opgegeven procedure niet vinden.
14:28:35 During initialization the error "DLL load failed while importing _coin: Kan opgegeven procedure niet vinden." occurred in freecad.freecad_glider
14:28:35 --------------------------------------------------------------------------------
14:28:35 Traceback (most recent call last):
File "C:\Program Files\FreeCAD_0.20\bin\lib\site-packages\freecad\freecad_glider\init_gui.py", line 3, in <module>
from . import _coin
- ubeamcnc.FCStd
- (108.29 KiB) Downloaded 39 times
