Dark and Light FreeCAD stylesheets (v1.8a)
pablogil
Re: Dark and Light FreeCAD stylesheets (v1.8a)
Postby pablogil » Mon Sep 19, 2016 7:41 am
easyw-fc wrote: Hi @pablogil
I'm porting my macro and I'm trying to use QT layout
I have a part of the macro using this code:
   pal = QtGui.QPalette()
   bgc = QtGui.QColor(shape_col[0]*255,shape_col[1]*255, shape_col[2]*255)
   pal.setColor(QtGui.QPalette.Base, bgc)
   ui.plainTextEdit.viewport().setPalette(pal)
when used in standard FC basic configuration (no style applied) the code works fine
but using a stylesheet theme the boxes became transparent
Is there a way to have a box colored inside also when using theme stylesheet?
Thank you
Maurice
I guess you are using the last stylesheet included into vanilla FreeCAD 0.16 and not this v1.8a version, doesn't it?
Anyway it is a clearly a bug, in order to help me fixing it, could you share with me this macro so that I'm able to reproduce the error (popup window with QPalette)?
Thanks
PS - Other thing that could help me: could you tell me the hierarchy you have used to create the QT GUI?
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
easyw-fc
Postby easyw-fc » Mon Sep 19, 2016 8:30 am
Thank you
Maurice
Thanks
Hi, the macro is kicad-StepUp-tools.FCMacro inside the demo here
https://sourceforge.net/projects/kicads ... t/download
To activate the colored box just create a cube in Part Design, select it and click on the button "Export to kicad" with 'wrl mat' ticked
Please note that the main Window is still not built using the QT Layout (that will take longer :) )
I tested it both on FreeCAD 0.17 8443 and FC 0.16 6706
thank you
Maurice
pablogil
Postby pablogil » Mon Sep 19, 2016 8:38 am
@easyw-fc
OK, tested and I could arrive to the problematic place, I will try to solve the issue.
Anyway, I see your GUI still has layout problems, do you still place the buttons by XY coordinates?
easyw-fc
Postby easyw-fc » Mon Sep 19, 2016 9:54 am
pablogil wrote:@easyw-fc
thanks :D
pablogil wrote: Anyway, I see your GUI still has layout problems, do you still place the buttons by XY coordinates?
I know :oops:
I'm working on that, but it will take some time to re-write all the main window and check all working functions...
Maurice
easyw-fc
Postby easyw-fc » Tue Sep 20, 2016 8:17 am
Hi, is there a way to set geometry appearance as in standard (no-stylesheet) GUI?
I mean when I switch from no-stylesheet to i.e. Dark-blue theme Text inside the buttons get cropped...
I know I can insert some style inside the app i.e.
self.RotateX.setStyleSheet('QPushButton {right: 2px; color: red;}')
but I don't know which style should I apply to reset the geometry to the one applied in the standard (no-stylesheets) GUI...
Thank you
Maurice
pablogil
Postby pablogil » Tue Sep 20, 2016 11:19 am
easyw-fc wrote: Hi, is there a way to set geometry appearance as in standard (no-stylesheet) GUI?
Thank you
Maurice
The easiest way is to add your custom code to the buttons, but I don't know if it will override the stylesheet... just try.
I guess the code you have to override is:
QPushButton {
    padding: 0px;
    margin: 0px;
Let me know
easyw-fc
Postby easyw-fc » Tue Sep 20, 2016 3:35 pm
pablogil wrote: The easiest way is to add your custom code to the buttons, but I don't know if it will override the stylesheet... just try.
QPushButton {
    padding: 0px;
    margin: 0px;
Let me know
Hi, I tried to add just
KSUWidget.setStyleSheet('QPushButton { padding: 0px;margin: 0px;}
but the buttons don't behave very well ... they just miss all the other values
I added more parameters...
KSUWidget.setStyleSheet('QPushButton { border: 1px solid #5a5a5a;border-radius: 0px;min-width: 50px;min-height: 20px;padding: 1px 2px;}')
but there were the hover functionality missing...
to add that one I would need to know the default values from the standard theme...
I tried applying i.e. the one of the Dark-blue
KSUWidget.setStyleSheet('QPushButton:hover,QPushButton:focus { color: white; border-color: #3874f2; background-color: qlineargradient(spread:pad, x1:0, y1:0, x2:0, y2:1, stop:0 #5e90fa, stop:1 #3874f2);}')
and they work, but what I would need as behavior would be to just set
and have the others as from the adopted theme.... :?:
Do you think it would be possible?
My need comes from the fact that I have many buttons with quite text inside that will be cropped when leaving the standard theme...
thank you again
Maurice
PS I managed to solve the other issue (color for TextEdit background) reworking my code and not using Palette
pablogil
Postby pablogil » Tue Sep 20, 2016 5:19 pm
easyw-fc wrote: Do you think it would be possible?
thank you again
Maurice
Umm, I don't think so is possible, anyway I'm not a C++ coder so I don't know if there is a way to do it as you suggest.
Anyway, I think you should learn how to create QT layouts, you will find there are not difficult and your GUI will behave much better than your actual one.
Just guessing, do you think setting a longer X size for buttons would work? I mean, if you set the button width big enough to show all the text inside then you don't need to bother about custom stylesheets...
easyw-fc wrote: PS I managed to solve the other issue (color for TextEdit background) reworking my code and not using Palette
OK, that's great, then I won't try it, better if you solved it with your code.
easyw-fc
Postby easyw-fc » Tue Sep 20, 2016 6:14 pm
pablogil wrote:
easyw-fc wrote: My need comes from the fact that I have many buttons with quite text inside that will be cropped when leaving the standard theme...
What I need is just a way to acquire style values for i.e. QtPushButton in the actual theme, then I can apply all the values, changing only what I need...
pablogil wrote: Anyway, I think you should learn how to create QT layouts, you will find there are not difficult and your GUI will behave much better than your actual one.
this is not a problem, I've already ported the GUI just using QT Layout and Grid Layout
pablogil wrote: Just guessing, do you think setting a longer X size for buttons would work? I mean, if you set the button width big enough to show all the text inside then you don't need to bother about custom stylesheets...
but, as I have many buttons, with large text inside, changing to your themes, the buttons would need to be too much bigger and so the GUI getting a big size of the working area....
Is there a way to acquire the style values from the current theme usingPySide?
thank you again
Maurice
pablogil
Postby pablogil » Fri Sep 23, 2016 6:58 am
easyw-fc wrote:but, as I have many buttons, with large text inside, changing to your themes, the buttons would need to be too much bigger and so the GUI getting a big size of the working area....
I don't know, I just know how to style QT, I'm not C++ or Python coder... :(
