fcinfo utility
yorik
Founder
fcinfo utility
Post by yorik »
With git commit c7440ef, I added a little utility in src/Tools called fcinfo. By using it on a FreeCAD file like this:
fcinfo myfile.FCStd
It prints the following text:
Document: test.fcstd (73K)
   SHA1: 14e427fb29a614f39a02c99433b06d67f292e23d
   Comment :
   Company :
   CreatedBy : Yorik van Havre <xxx@xxx.xx>
   CreationDate : 2015-06-26T17:27:35-03:00
   FileVersion : 1
   Id :
   Label : structure-test
   LastModifiedBy : Yorik van Havre <xxx@xxx.xx>
   LastModifiedDate : 2015-06-26T18:23:31-03:00
   License : CreativeCommons Attribution
   LicenseURL : http://creativecommons.org/licenses/by/4.0/
   ProgramVersion : 0.16R5121 (Git)
   Uid : 7d02aff3-beb6-43f4-b4cc-18fd60492fce
   Objects: (4)
       Shape : Part::Feature (342K)
       Structure : Part::FeaturePython (3K)
       Structure001 : Part::FeaturePython (3K)
       Structure002 : Part::FeaturePython (3K)
It might of course be extended, but the idea is to provide a nice readable to humans description of the contents of a freecad file, and also serve for text-based diffs. Since it inclues a hash code, you're sure to get a difference even if the contents of the file appear the same. For ex:
./fcinfo test.fcstd > t1.txt && ./fcinfo test.fcstd1 > t2.txt && diff t1.txt t2.txt
which is the same file, I only pressed the "save" button, gives:
1,2c1,2
< Document: test.fcstd (73K)
<    SHA1: b2ffae4562f1ebf510654af8b913414cdd33e966
> Document: test.fcstd1 (73K)
11c11
<    LastModifiedDate : 2015-06-27T20:08:22-03:00
This utility can also be used by git, if you manage a git repo that contains freecad files, git can use this to show you a diff between two files. This is just for viewing purpose, the files are still considered binary by git, and stored as full copies (instructions there: https://git-scm.com/book/en/v2/Customiz ... Attributes )
drei
Re: fcinfo utility
Post by drei »
@ yorik,
Pardon my ignorance, but how do I enable the tool after compiling FreeCAD? Did I need to add a new CMake flag or something? I went to my build directory, but there isn't a Tools folder under src.
Founder
Re: fcinfo utility
Post by wmayer »
I haven't looked at it but it looks like it's an independent script not related at all to the FreeCAD application.
mario52
Re: fcinfo utility
Post by mario52 »
hi
it is not likely to be confused with the macro FCInfo
(a suggestion why not appoint fcstdinfo )
est ce qu'il ne risque pas d'y avoir une confusion avec la macro FCInfo
(une suggestion pourquoi ne pas la nommer fcstdinfo )
mario
yorik
Founder
Re: fcinfo utility
Post by yorik »
@drei yes it's just a little independent python script. No need to compile, and it is not installed (at the moment). If you want to use it, just copy it (or link it) from the source tree to some place in your exec path. Not sure it works out of the box on windows, though, it might require some testing...
@mario good point.. Maybe we should rename it...
mario52
Re: fcinfo utility
Post by mario52 »
hi
thanks
hmk
Feature request: Support backup file extensions
Post by hmk »
I think it would be useful to also support .FCStd1, .FCStd2, ... extensions. (Perhaps at least from 1 up to 9.)
For example, this would allow to directly diff the current version with the most recent backup:
diff <(fcinfo x.FCStd) <(fcinfo x.FCStd1)
(Not sure if this the right/best place for a feature request, please let me know if I should do this at a different spot.)
Chris_G
Re: fcinfo utility
Post by Chris_G »
hmk wrote: Fri Dec 18, 2020 5:33 pm I think it would be useful to also support .FCStd1, .FCStd2, ... extensions. (Perhaps at least from 1 up to 9.)
PR submitted.
kisolre
Re: fcinfo utility
Post by kisolre »
This should also support the new FCBak... format.
Chris_G
Re: fcinfo utility
Post by Chris_G »
OK, FCBak support added
