Arch precast concrete tools
yorik
Site Admin
Postby yorik » Mon Jun 13, 2016 3:06 pm
The Arch Structure tool has now been extended with a series of new presets to build precast concrete elements like these:
This is all available from the structure creation tool, one just has to select the "precast concrete" preset, there are currently 5 available items: beam, pillar, I-beam, slab and panel. Of course, the settings are all parametric.
Enjoy!
precast examples.FCStd
(62.92 KiB) Downloaded 76 times
chakkree
Re: Arch precast concrete tools
Postby chakkree » Mon Jun 13, 2016 3:46 pm
+1
Excellent!
triplus
Postby triplus » Mon Jun 13, 2016 10:20 pm
Nice feature!
chakkree
Postby chakkree » Tue Jun 14, 2016 12:26 pm
Test Export Precast Object to IFC.
Tested on:
Version: 0.17.7731 (Git)
Hash: dea884ab6a4a748cd61cb593ee91f0eef1bdb603
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Test_Precast4.ifc
(107.1 KiB) Downloaded 73 times
yorik
Site Admin
Postby yorik » Tue Jun 14, 2016 4:22 pm
Hm still some problems apparently :D
I have many problems recently with extrusions in IFC... it seems that the missing objects are all extrusions. I'll have a better look.
chakkree
Postby chakkree » Tue Jun 14, 2016 4:45 pm
Test Create ArchPrecast with Macro.
  for Test Create ArchPrecast
import FreeCAD
from ArchPrecast import _PrecastBeam , _ViewProviderPrecast
from ArchPrecast import _PrecastIbeam
from ArchPrecast import _PrecastSlab
from ArchPrecast import _PrecastPanel
from ArchPrecast import _PrecastPillar
def makePrecastBeam(Length = 3800 , Width=200 ,Height = 400):
    a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Precast Beam")
    _PrecastBeam(a)
    _ViewProviderPrecast(a.ViewObject)
    a.DentLength = 200
    a.DentHeight = 200
    a.Chamfer = 18
    a.Length = Length
    a.Width=Width
    a.Height = Height
    return a
def makePrecastIbeam(Length = 3800 , Width=200 ,Height = 400):
    a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Precast I Beam")
    _PrecastIbeam(a)
    a.BeamBase = 100
    a.Chamfer=50
    a.Length = Length
    a.Width=Width
    a.Height = Height
    return a
def makePrecastSlab(Length = 3800 , Width=1000 ,Height = 300):
    a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Precast Slab")
    _PrecastSlab(a)
    a.SlabBase = 100
    a.Length = Length
    a.Width=Width
    a.Height = Height
    return a
def makePrecastPanel(Length = 3800 , Width=300 ,Height = 40):
    a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Precast Panel")
    _PrecastPanel(a)
    a.Length = Length
    a.Width=Width
    a.Height = Height
    return a
def makePrecastPillar(Length = 300 , Width=300 ,Height = 4000):
    a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Precast Pillar")
    _PrecastPillar(a)
    a.Length = Length
    a.Width=Width
    a.Height = Height
    return a
B1 = makePrecastBeam()
B1.Label= 'PrecastBeam'
B1.Placement.Base.y=1000
B2 = makePrecastIbeam()
B2.Placement.Base.y=2000
S1 = makePrecastSlab()
S1.Placement.Base.y=3000
S1.HoleSpacing = 200
S1.HoleMajor=100
S1.HoleMinor=100
S1.HoleNumber = 3
S2 = makePrecastPanel()
S2.Placement.Base.y=4500
C1 = makePrecastPillar()
FreeCAD.ActiveDocument.recompute()
Tested on:
chakkree
Postby chakkree » Tue Jun 28, 2016 9:02 am
Test Export ArchPrecast Object to IFC.
Clone of ArchPrecastSlabBeam can export to IFC.
Clone of ArchPrecastSlab can not export to IFC.
yorik
Site Admin
Postby yorik » Tue Jun 28, 2016 2:34 pm
Thanks for testing!
I made some small changes to the Precast stuff after that file was made, I had to change it a little bit. Now it works:
(59.3 KiB) Downloaded 49 times
bitacovir
Postby bitacovir » Mon Jul 04, 2016 10:28 am
it is great! Good work!
But I noticed one thing that can be confuse.
1) the default beam, panel, pillar all have Height 1,000mm; length 100mm; Width 100mm. I think for beam should be height 300mm width 300mm and length 3,000mm And for pillar height 2000mm, width 200mm length 200mm (or something like that).
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Mon Jul 04, 2016 2:17 pm
It uses the default structure settings in preferences->Arch->defaults. The idea is that you set a default for a column, or a beam, and then on creation you use the "switch X/Z" button to quickly invert these values when making a horizontal or vertical element...
Of course there is space for improvement there, but I didn't want too complex preferences settings, this seemed a good and flexible way...
