Per-face transparency
yorik
Site Admin
Postby yorik » Thu Jul 07, 2016 4:04 pm
With git commit 43e0834 it is now possible to have per-face transparency like this:
It is a very small code change actually, everything was there already. When you use the "set colors" tool to set individual colors for selected faces, the DiffuseColor property is filled with a list of colors with the same length as the number of faces. These colors already had an alpha value, but it was simply not used.
There is one catch: colors are written as (red, green, blue, alpha). The alpha value, normally, is understood as: 0 = fully transparent and 1 = fully opaque. In FreeCAD however, all colors until now have always been saved with their alpha value at 0. This actually makes some sense, because FreeCAD doesn't use the concept of alpha, but the concept of transparency (inherited from coin), where 0 = opaque and 1 (or 100%) = transparent.
So in order to not make existing objects suddenly become fully transparent, this implementation respects the FreeCAD idea and the alpha value of colors should therefore be understood not as alpha, but as transparency (0 = opaque -> 1 = fully transparent).
At the moment, the color editor of FreeCAD cannot set transparency, so the only way to set per-face transparency is from python. For example, if you have an object with 4 faces, you can do this:
myObject.ViewObject.DiffuseColor = [ (0.0,0.0,1.0,0.0) , (0.0,1.0,1.0,0.25) , (1.0,1.0,1.0,0.5) , (1.0,1.0,0.0,0.75) ]
triplus
Re: Per-face transparency
Postby triplus » Thu Jul 07, 2016 11:07 pm
Looking good.
P.S. The ability to apply it directly from GUI would make it much more useful.
easyw-fc
Postby easyw-fc » Fri Jul 08, 2016 6:36 pm
yorik wrote:With git commit 43e0834 it is now possible to have per-face transparency ....
Hi, I know I'm bit out of topic...
Is there a way (may be with python) to save a solid to STEP conserving transpatency?
I know it can be done for BREP models in native FreeCAD format, but I haven't found a way to do it for STEP format...
Thanks
Maurice
NormandC
Postby NormandC » Sat Jul 09, 2016 6:52 pm
Hello Yorik,
Nice addition, I'm guessing you'll soon use this for Arch Windows? :)
yorik
Site Admin
Postby yorik » Sat Jul 09, 2016 11:42 pm
NormandC wrote:Nice addition, I'm guessing you'll soon use this for Arch Windows? :)
No. It's ALREADY used by the arch window :ugeek:
NormandC
Postby NormandC » Sun Jul 10, 2016 12:42 am
Great!!! :D
I've been meaning to finally give a real go to the Arch workbench by modelling my new house. :)
But maybe that will wait for after the summer. :lol:
pablogil
Postby pablogil » Mon Jul 11, 2016 9:30 am
Cool!
I guess the GUI option will be included into "set colors..." window, doesn't it?
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
yorik
Site Admin
Postby yorik » Mon Jul 11, 2016 1:38 pm
pablogil wrote:I guess the GUI option will be included into "set colors..." window, doesn't it?
Honestly I haven't looked at that yet. I think the current color picker dialog is a standard Qt dialog. We would need to recode our own dialog there, plus there is the problem that our alpha scale is "inverted". This is not a small task...
Maybe there would be a way to just extend the color dialog to include a transparency value slider or something... Not sure how easy it is to do, I'll have a look.
pablogil
Postby pablogil » Mon Jul 11, 2016 4:11 pm
Thanks!
bill
Postby bill » Sun Jul 24, 2016 2:30 pm
Very handy yorik!
Hey Rentlau: Another tool for the WORK FEATURE toolbox! :o
