Transform utility gets an upgrade in 0.17
NormandC
Post by NormandC »
I noticed it not long ago but forgot to post about it.
Surely you've happened to double-click on a Part object in the Model tree expecting to open its parameters in the Tasks panel like for PartDesign features.
But instead you got this:
This is the Transform utility. After your initial "WTF" moment, you experimented with it, and found you could somewhat move and rotate the object with this tool. You quickly realized that its usefulness was severly limited because it's impossible to control the move/rotate precisely.
Next you wondered how the heck to get out from this mode. (Hint: right-click on the shape label in the tree and choose "Finish editing"). And finally you really, really tried hard to avoid this utility altogether. :D
Well, the transform utility got an awesome upgrade in 0.17! Here's how it looks like now:
It's a lot easier to use:
  • Press and hold the left mouse button on an axis arrow and drag to translate the object in that direction.
  • Press and hold the left mouse button on a sphere and drag to rotate the object in that axis.
  • The Increments parameters in the Tasks panel allow you to define the movement with precision
  • The OK button allows you to quit the utility easily.
jaisejames
Re: Transform utility gets an upgrade in 0.17
Post by jaisejames »
Will this OK button apply default value or it act as cancel button. Or we need to clear value boxes & press Ok?
NormandC
Post by NormandC »
As soon as you rotate/move the object in the 3D view, changes are applied. There is no Cancel button. The value boxes are for increments, not absolute values. OK only serves to exit the utility. But you can undo afterwards.
r-frank
Post by r-frank »
Hello Normand.
Thanks for reporting.
A candidate for the release notes 0.17 ... :)
Roland
My GrabCAD FreeCAD-Projects
renatorivo
Post by renatorivo »
Using the tool Increments, FreeCAD crashes.
I have not yet figured out exactly when
I get this message
renato@renato-MS-7846:~$ freecad-daily
FreeCAD 0.17, Libs: 0.17R8819 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2016
Fasteners workbench Loaded
Sheet Metal workbench loaded
Mod pluginloader InitGui.py starting ...
pluginmanager config file /usr/lib/freecad//Mod/plugins/pluginloaderconfig.yaml
pluginmanager userconfig file /usr/lib/freecad/Mod/plugins/myconfig.yaml
dict
{'menu test - cmd2': {'exec': 'import plugins;plugins.plugin1.p1.info1()'}, 'menu tes - fun': {'exec': 'FreeCAD.ActiveDocument.addObject("Part::Box","Box")'}, 'menu test - command1': {'exec': 'import plugins;plugins.plugin1.info2()'}}
{'author': 'noname',
 'backup': '/usr/lib/freecad-daily/tmp/bak2_',
 'description': 'no description',
 'destdir': '/home/renato/.FreeCAD/Mod/testdir',
 'exec': "import FreeCAD;FreeCAD.Console.PrintWarning('*****default Method FreeCAD-Dir=/usr/lib/freecad-daily/! HOME-Dir=/home/renato/!  UserData-Dir=/home/renato/.FreeCAD/!\\n')",
 'format': 'zipdir',
 'icon': '/usr/lib/freecad-daily/Mod/plugins/icons/master.png',
 'menu': 'defaults',
 'method': 'zip',
 'name': 'defaultName',
 'source': 'https://github.com/microelly2/plugin_defaults/archive/master.zip',
 'sourcedir': 'plugin_defaults-master',
 'status': 'ignore',
 'timestime': 'https://github.com/microelly2/plugin_defaults/timestamp'}
dict
{'files': ['dark-green.qss', 'dark-blue.qss', 'dark-orange.qss', 'light-green.qss', 'light-blue.qss', 'light-orange.qss'], 'pattern': '\\[PATH_TO_IMAGES\\]', 'data': 'UserAppData/Gui/Stylesheets/images'}
Mod pluginloader InitGui.py done
During initialization the error "'gearWorkbench' already exists." occurred in /home/renato/.FreeCAD/Mod/FCGear-master/InitGui.py
gentoolbars ...
gentoolbars ...
ky:my PartTools
Move
my PartTools
{'icon': 'icons:Draft_Move.svg', 'exec': 'import DraftTools;DraftTools.Move().Activated()'}
mars
my PartTools
{'icon': '/usr/lib/freecad/Mod/plugins/icons/sun.png', 'exec': 'fn="AppHomePath/Mod/plugins/status.py";d={};exec(open(fn).read() + "\\nsun()\\n",d,d)'}
sun
my PartTools
{'icon': '/usr/lib/freecad/Mod/plugins/icons/mars.png', 'exec': 'fn="AppHomePath/Mod/plugins/status.py";d={};exec(open(fn).read() + "\\nmars()\\n",d,d)'}
my PartTools done
*** Abort *** an exception was raised, but no catch was found.
	... The exception is:SIGSEGV 'segmentation violation' detected. Address 3e000000001
OS: Ubuntu 16.04.1 LTS
Version: 0.17.8819 (Git)
Build type: None
Hash: 195ea429e696377980b4edbf4a4affdb1f46abaa
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Renato
Edit also with FreeCAD 0.17.8856
renatorivo
After a rotation around the Z axis (about 270°), and a translation along the Y axis (green), the cube has this aspect
OS: Windows 8.1
Version: 0.17.8856 (Git)
Hash: c465ca261ce3289daf427cb30a5626c159232287
Python version: 2.7.8
OCC version: 7.0.0
Same thing on Linux
Renato
bejant
Post by bejant »
NormandC wrote:Surely you've happened to double-click on a Part object in the Model tree expecting to open its parameters in the Tasks panel like for PartDesign features.
Someone once called it "the gyroscopic mover and shaker of death". Thanks for mentioning the upgrade, it's much more usable now.
No crash and have not been able to reproduce the clipping plane issue here using:
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Build type: None
renatorivo
bejant wrote:have not been able to reproduce the clipping plane issue here using:
strange,
Part -> Cube -> Axonometric view -> double-click Cube gives this view
drag along the X axis, after a while becomes so
Build type: None
I cannot reproduce it, though I had seen this behaviour before, but could never reliably reproduce it. If I remember right I had it while just rotating the view (without edit mode), but I am not sure.
Did you try it with a fresh FreeCAD instance and a fresh document? I tried: start freecad-daily -> new document -> select part wb -> Cube -> Axonometric view -> double-click. And did you just dragged with mouse button down or did you double click on the arrow and moved the mouse? I tried both and had no problems.
OS: Ubuntu 14.04.5 LTS
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
renatorivo
chrisb wrote:Did you try it with a fresh FreeCAD instance and a fresh document? I tried: start freecad-daily -> new document -> select part wb -> Cube -> Axonometric view -> double-click. And did you just dragged with mouse button down or did you double click on the arrow and moved the mouse? I tried both and had no problems.
here in windows, same thing, a portion of the cube disappears
OS: Windows 8.1
OCC version: 7.0.0
