STEP interchange enhancements
easyw-fc
Post by easyw-fc »
During last year many activities have been done to improve STEP feature for FreeCAD.
Because with the latest PR#871 that @vejmarie has done many issues/features have been solved/raised.
I'm going to resume the most interesting new features added:
1) STEP file size
following this thread
https://forum.freecadweb.org/viewtopic. ... 85#p142700
the file size of STEP files can be now reduced up to 5 times in many cases... this is an old known problem that now has been solved!
2) STEP file loading time
https://forum.freecadweb.org/viewtopic. ... ng#p158225
the loading time has been improved so much that STEP file loading now is faster than some commercial CADs
3) STEP file handling
https://forum.freecadweb.org/viewtopic. ... 90#p159741
using VBO and OpenGl FreeCAD is now able to manage extremely complex STEP files, having frames per seconds similar to best commercial CADs
4) STEP import
https://forum.freecadweb.org/viewtopic. ... 36#p156821
the STEP importer now has a hierarchy when present in the file itself, creating App::Part containers perfect for Assembly structure
Finally FreeCAD integrates a hierarchy when reading STEP files, instead of a FLAT structure, as it was till now.
5) STEP export
https://forum.freecadweb.org/viewtopic.php?f=17&t=23368
the STEP exporter now can save a STEP file conserving the hierarchy as present when loaded.
Using App::Part containers it is also possible to create an Assembly structure to be exported as single hierarchical STEP file as in commercial CADs.
Many many many thx to @vejmarie to take care of this big job!
I'm also proud to have discovered the riddle for the file size issue.
And of course many thx to all FC developers to make this great MCAD sw!
Maurice
Re: STEP interchange enhancements
Post by Kunda1 »
Nice post! and thanks @vejmarie !
easyw-fc
Post by easyw-fc »
Kunda1 wrote: Tue Jul 11, 2017 10:48 amNice post!
here the screenshot of a SW STEP file posted by a user, with hierarchy in the STEP loaded file in FC
and here the same hierarchy of the file exported by FC and re-opened
you can see groups inside the tree
Maurice
pablogil
Post by pablogil »
AWESOME!!
and thank you very much!
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
saso
Post by saso »
vejmarie to the hall of fame! :)
Post by Kunda1 »
easyw-fc wrote:ping
Can you take a look at issue #2369 testing the new commits?
easyw-fc
Post by easyw-fc »
Kunda1 wrote: Tue Jul 11, 2017 10:21 pm Can you take a look at issue #2369 testing the new commits?
the testing file is
arietta.7z
(710.38 KiB) Downloaded 161 times
as you can see both in FC with latest commits and in CADA the result contains groups.
Before (i.e. FC01.6) the loaded file had only a FLAT representation of the objects
there is just a strange issue related at the finishing loading time, which is much longer for this file compared to others
vejmarie
Post by vejmarie »
Curious to better understand the small issue you reported ;).
easyw-fc
Post by easyw-fc »
vejmarie wrote: Wed Jul 12, 2017 7:40 am Curious to better understand the small issue you reported ;).
the file I attached in my previous post just load fine and the loading bar goes till 100%, but then FC still hangs for quite a long time till the file is completely displayed.
This behavior is not present in CADAssistant, nor in DSM
You can test it unzipping and loading the file
https://forum.freecadweb.org/download/file.php?id=40122
Maurice
vejmarie
Post by vejmarie »
I have been able to reproduce the issue. I will check it. Roughly and as a short explanation the phase where you see the progress bar is the phase during which opencascade is reading the file and translate the STEP into OCCT Shape. The following step is the step during which I am re-organizing "properly" the shape into FreeCAD document, and translate that into a usable format (Part::Feature, Compound etc ...), some object creation can take a crazy amount of time in some cases. I will track this stuff as soon as I have written the "merge" patch
