Manipulator WorkBench
Re: Manipulator WorkBench
Wow, this WB is really cool, especially dimensioning
So i have a question in this regard:
Would it be possible to align a PointToPoint measurement to a user selected edge?
That would allow to imitate some measuring in a "local" CS.
Would you please post an edited image to reflect the wanted result?
Probably it would need to be added a reference plane for laying the dimension... I'm not sure if this can be easily added ...
M
...it seems that you must use helper draft-lines to get the measure.
End/midsnap, perpendicular/parallelsnap, centersnap....
In my example fontsize-controlling has some restrictions - I cant change it.
Angle measurement between planes must also be done with helper lines/edges/wires.
Hi @hammaxhammax wrote: ↑Mon Oct 16, 2017 6:11 am ...it seems that you must use helper draft-lines to get the measure.
the Caliper is working in the same philosophy of the DSM Caliper: you get fast measurement for 3D parts
It is not intended to be a Dimension tool like this of DSM
I can try to add an annotation plane to modify in some way the dimension created.
I'm not familiar to ViewObserver, so I cannot bet on the results..
If someone would like to fork the repo and suggest some improvement with a pull request, I will be happy to merge it.
As I replied in my previous post, the fonts are fixed size in the macro, but they could be attached to the Draft preference value (not done ATM).
Anyway it is possible to change the properties of each dimension in its corresponding Tab
Maurice
Hi @UR_
I have added a first implementation of the Annotation Plane to make the Caliper a bit more flexible..
It takes some more click to have the measure, but it gives users the ability to place the dimension with some degree of freedom...
(this is a feature that can be enabled or not by the user)
The following is a preview of the new behavior...
a small update for the Caliper
an other small feature:
Parallel Planes distance measure
This measure is available from Angle measurement button, when two Planes are Parallels.
This is working also if planes are not on standard axis.
Wow cool measure normal distance of parallel faces
Is it possible to measure the normal distance of edges which go in the same direction?
thx
that is already implemented ... when measuring Angles between parallel edges, the measure will return angle 0 and the normal distance between the edges.bernd wrote: Is it possible to measure the normal distance of edges which go in the same direction?
ATM I have an issue when the objects are rotated that I need to solve ...
