Manipulator WorkBench
manos
Re: Manipulator WorkBench
Post by manos »
So simple . Too good to be true !
I will try it.
Thanks easyw-fc .
manos
Post by manos »
manos
Post by manos »
easyw-fc wrote: Sun Jun 06, 2021 1:31 pm Simply de-select App::Part hierarchy checkbox
Sorry easyw-fc ,bad news.
I de-select the part-container and I selected only one edge of one object -box- : Both objects, both bodies move simultaneously using Manipulator Mover .
Any workaround ?
easyw-fc
Post by easyw-fc »
manos wrote: Sun Jun 06, 2021 7:47 pm Sorry easyw-fc ,bad news.
Any workaround ?
please post the FC file and possibly a screencast of what is not working as desired
manos
Post by manos »
easyw-fc this the problematic file.
Thanks for the response.
Basic Attachment Tutorial 1.FCStd
(62.04 KiB) Downloaded 133 times
easyw-fc
Post by easyw-fc »
manos wrote: Mon Jun 07, 2021 8:30 am easyw-fc this the problematic file.
Hi
I tried with your file but Mover seems too work correctly...
manos
Post by manos »
Thanks easyw-fc.
I will send you the screencast.
manos
Post by manos »
manos wrote: Sat Jun 05, 2021 5:25 pm I have a part-container with two bodies inside. Is there any way to move one body only using Manipulator?
I am stupid.
I have just to uncheck the hierarchy button.
Thanks easyw-fc
drmacro
Post by drmacro »
Just a quick couple of questions/thoughts.
There is a rather lengthy thread discussing the placement of imported objects. Particularly why they move back to their original location if they are dropped into a Part Design Body. https://forum.freecadweb.org/viewtopic.php?f=8&t=59269
When, for example, an stl is converted to a shape/solid it is rather easy to move the object's center of mass or bounding box to the origin. (I think Manipulator will only handle bounding box...?)
It would be nice if, on a tessellated shape/solid, to be able to select, say three vertexes or edges that represent, say a hole for a shaft, and be able to move the object from the extrapolated center of the selected vertex or edges to the origin (or any other specified place).
Is this possible with Manipulator at this point? I've not figured it out if it can.
If not, is it possible to add such features?
easyw-fc wrote: pinged by pinger macro
easyw-fc
Post by easyw-fc »
drmacro wrote: Sat Jun 12, 2021 1:33 pm When, for example, an stl is converted to a shape/solid it is rather easy to move the object's center of mass or bounding box to the origin. (I think Manipulator will only handle bounding box...?)
Hi @drmacro
ATM it is not possible to handle the center of a mesh shape, coming from 3 points... (I'm not using mesh objects in my normal workflow)
I'm thinking to add a function to create a point at the approximate center, and attach it to a new added 'Part' container...
From there on, it would be possible to Align the 'Part' container using the new created 'center-point' as reference.
Would be it a useful workflow?
