Manipulator WorkBench
regis
Re: Manipulator WorkBench
Postby regis » Fri Oct 06, 2017 10:32 pm
your workbench seems to have the most colorful display of icons. seems u've been hard at work creating icons aswell. ;)
oddtopus
Postby oddtopus » Sat Oct 07, 2017 6:30 am
Yesss! That WB will improve drastically the efficiency of working with FreeCAD.
I just have a feature request:
I talked here https://forum.freecadweb.org/viewtopic.php?f=8&t=23965 about the possibility to use "handles", i.e. graphic objects that are temporarily drawn next to the object in the viewport. These handles could be grabbed and draged so to manipulate graphically the object, like in SweetHome3D.
I started to create a class for such auxiliary objects (polarUtilsCmd.arrow() and polarUtilsCmd.label3D() in flamingoWB). Actually I use them only to indicate directions of translation and rotation, but if you want you may take some snippet of that code and add a node to the scene-graph to make them selectable. I think that doing so, you only need to add the code to perform the manipulation.
...now I'm thinking about others possibilities and code snippets (for a spinner, for example) that can be used but this post's becoming too long. May I share some ideas with you in a private message?
easyw-fc
Postby easyw-fc » Sat Oct 07, 2017 7:10 am
Thx :)
yes, you can reach me in PM .. I would be happy to see if I can add some handles with some existing class...
Maurice
easyw-fc
Postby easyw-fc » Sun Oct 08, 2017 9:43 pm
It is now on the official FC addons repo! :D
So it is easier to install it!
Because I was missing also some measurement when using App::Part objects (because of Draft Snap issue), I started to add to the Manipulator WB also a Caliper ...
Here some first tests (at a very early stage):
thschrader
Postby thschrader » Fri Oct 13, 2017 1:10 pm
Nice work!
Just saw a fresh "first-look"video from Paul Randall about manipulator-wb
on youtube:
https://www.youtube.com/watch?v=xMBvvDiMHVo
easyw-fc
Postby easyw-fc » Fri Oct 13, 2017 9:25 pm
Nice work!
Thx :D
thschrader wrote: Just saw a fresh "first-look"video from Paul Randall about manipulator-wb
on youtube:
thx for pointing this out :)
Nice to see my WB at work!
PS then I can also improve features, because of the feedback ;)
Maurice
PPS latest feature: Angle measurements
Jee-Bee
Postby Jee-Bee » Sat Oct 14, 2017 8:00 am
Based on your picture it looks like a lot of clicks before having an angle measurement...
(face1, edge1, face2, edge2) Why not just edge1 and edge2 for angle between edges and face1 and face2 for an between surfaces?
easyw-fc
Postby easyw-fc » Sat Oct 14, 2017 1:32 pm
Based on your observations it looks like you haven't event tried the WB before your comment :P
What you see in the gif is just the mouse over the face highlighting...
The WB selection works like that:
If you have Angle measurement selected, you just need to select the first edge and then the second and the Dimension will appear.
(Angle between Faces is not implemented yet)
If you have Radius or Length selected, you just need to select an Edge to get the Dimension appearing.
If you have Bounding Box or Center of mass selected, you can just click on a Vertex or an Edge or a Face to get the corresponding BoundigBox/Mass Center point appearing.
If you have Snap to End, Middle or Center enabled, you can just select an Edge to get the End point or the Middle point whatever it is the closest to the position clicked. If you click on a face you get its Center.
This is IMO the less click you can do to get these results.
Please have a try with the WB ... that could help in refining its behavior in case of need.
Thx
Maurice
hammax
Postby hammax » Sat Oct 14, 2017 3:25 pm
...will there be also an angle between faces (is not implemented yet)? Minimum angle orthogonal to common edge?
Another item would be the possibility of preformatting or general formatting of the measure view.
Font, distances and the other stuff in ViewTab.
easyw-fc
Postby easyw-fc » Sat Oct 14, 2017 7:51 pm
just implemented angle between normals to Faces/Planes :)
I'm using DisplayMode: "3D", so the text is auto dimension itself as well as it is done for Part Measure tools.
It could be an option to use the same Font size used by Draft, in case of need...
in this case it wouldn't have any need to have a configuration tab, using the Draft preferences instead
