Manipulator WorkBench
f3nix
Re: Manipulator WorkBench
Postby f3nix » Sat Jan 25, 2020 5:52 am
Hi once again.
I think the main issue is missing layouts for some objects. See screenshot.
Cheers,
Mateusz
EDIT: added two more screenshots.
easyw-fc
Postby easyw-fc » Sat Jan 25, 2020 7:42 am
Hi Mateusz
thanks for going into this issue :D
f3nix wrote:
Sat Jan 25, 2020 5:37 am
I have played with using the layouts and I have the caliper working quite good.
great!
One thing is missing. Not all images are in svg format. The png files are missing.
All the images should be in svg format and should be embedded inside the macro...
EDIT:
I used the pngs only to have a reference in Qt designer... Ithink Qt4 designer didn't support svg icon, but I'm not sure
/EDIT
@line 1580 at Caliper you can find the list of icons
# embedded button images
Caliper.py#L1580
I used to convert the icons with the following script:
#!/usr/bin/python
# -*- coding: utf-8 -*-
import base64
import argparse, sys, os
args=sys.argv
if len (args) >1:
    fullfname=args[1]
    ext = os.path.splitext(os.path.basename(args[1]))[1]
    fname=os.path.splitext(os.path.basename(args[1]))[0]
    with open(fullfname, "rb") as image_file:
        encoded_string = base64.b64encode(image_file.read())
    with open(fname+"-b64.txt", "wb") as eb64_file:
        eb64_file.write(encoded_string)
Then the b64 encoded images could be decoded back to svg.
Here a sample to decode the images:
#!/usr/bin/python
import base64
fname = '/home/mau/Downloads/myimage_svg'
close_img=\
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
decoded_string = base64.b64decode(close_img)
print(decoded_string)
with open(fname+"-decoded.svg", "wb") as svg_file:
    svg_file.write(decoded_string)
Please let me know which image you miss and I will provide it.
Maurice
f3nix
Postby f3nix » Sun Jan 26, 2020 10:00 pm
Hi Maurice!
Thank you for the great tips. That got me going. I have tested the caliper and it looks good. Auto scaling when moving from high dpi monitor to a normal monitor seems to work good too (screenshots attached).
I have one more problem. The file measure-tool-docked-v1.5.ui does not seem to be in sync with the code used in Caliper.py. It is missing the blabel button (enable extra label). Could you please check that out?
Cheers,
Mateusz
f3nix
Postby f3nix » Sun Jan 26, 2020 11:45 pm
Hi.
Here are the files for align and mover tools. Please test them and write what you think. I can make a pull request if you like it.
Thanks for the awesome tools! :)
Cheers,
Mateusz
P.S. The python files were hand edited since the uic does not do a good job with all the parameters.
mover-tool-docked-v1.9-highdpi.ui
(23.72 KiB) Downloaded 5 times
mover-highdpi.py
(16.42 KiB) Downloaded 4 times
align-tool-docked-v1.6-highdpi.ui
(22.14 KiB) Downloaded 4 times
align-highdpi.py
(15.18 KiB) Downloaded 5 times
easyw-fc
Postby easyw-fc » Mon Jan 27, 2020 6:35 am
Hi.
Hi Mateusz
would you please point me to your repository @ github?
I will have a look at the code there and test the changes.
About the Caliper ui, I found the latest file... please find it attached
measure-tool-docked-v1.8_ui.zip
(2.13 KiB) Downloaded 5 times
Cheers,
Mateusz
would you please point out which edits did you do?
Maurice
f3nix
Postby f3nix » Mon Jan 27, 2020 6:14 pm
Hi.
Hi.
Hi Mateusz
Here it is: https://github.com/f3nix/Manipulator
Thanks :) The new file is already converted in my repo.
I have been using pyside2-uic tool.
1. I had to replace all QtWidgets with QtGui.
2. I had to add QtCore.Qt.AlignTop for the left upper buttons (the uic does not add them automatically - maybe a bug?)
Thanks for supporting me through this process.
Cheers,
Mateusz
easyw-fc
Postby easyw-fc » Mon Jan 27, 2020 9:46 pm
Cheers,
Mateusz
Hi Mateusz
thanks for your work on this HIDPI issue...
I'll have a look at the ui and I'll be back asap.
Maurice
easyw-fc
Postby easyw-fc » Wed Jan 29, 2020 10:00 pm
Mateusz
I've played a bit with the new layout, but what I'm missing is the ability to resize the full Dialog, make the other controls hidden...
I'm going to play a bit more and I'll update you here
Maurice
easyw-fc
Postby easyw-fc » Fri Jan 31, 2020 8:59 pm
Hi Mateusz
I've just added a hdpi branch to my repo
https://github.com/easyw/Manipulator/tree/hdpi
you can test the new Aligner with your HDPI screen
.. and, if you want, adapt the other tools...
then just poke me here or make a PR to the hdpi branch and I will merge it and finalizing the merging.
ATM I cannot find a way to keep the old behavior to minimize the dialog but the dialog can be placed behind the Combo Tab... so there is not a big defeat though...
Here some notes:
I'm using pyuic5 from pyqt5-dev-tools
I just have added
QtWidgets = QtGui
before the declaration of the 'class Ui_DockWidget(object)'
this is fixing the rest of the code
I moved the icons and that solved this issue in Aligner.
EDIT:
I have an issue with aligner because the 4 check boxes act all together instead of by row.
EDIT2:
Now it should work... still not the best solution
mario52
Postby mario52 » Sat Feb 01, 2020 2:06 pm
hi
for PySide2 Qt5 you must restore QtWidgets see my example code
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
