YAML Workspace
mambix
YAML Workspace
Postby mambix » Mon Feb 05, 2018 10:16 am
Last year I created new YAML Workspace as I needed to quickly import STL files into FreeCAD for pre-fabrication check. I design a lot of parts that need to be cut from plywood with CO2 laser cutter. To avoid fixing errors in design I have python scripts that create STL files from my DXF designs. And YAML workspace allows me to easily import parts and check them in 3D space for correct fit.
GitHub: https://github.com/Mambix/FreeCAD-yaml-workspace
Hopefully it makes more sense after looking at this short video:
phpBB [video]
In first part I manually import parts, move them, apply colour and transparency.
In last part of the video I use my YAML Workspace to automate the process.
So next time I fix something in my DXF files and recreate STL files. I can discard FreeCAD document and import it again with new shape.
Hope this tools comes handy to more people that look to automate their design and manufacturing process.
Re: YAML Workspace
Postby Kunda1 » Mon Feb 05, 2018 4:07 pm
Very cool. Does this work on Linux/MacOS as well ?
mambix
Re: YAML Workspace
Postby mambix » Mon Feb 05, 2018 4:48 pm
I will try on macOS.
I'm having issues with this on Linux atm. FreeCAD freezes on import. Did not figure out yet why. I need to investigate it more and then file a bug if it turns out to be one in FreeCAD. Don't think it has anything to do with the workspace code at this point.
Re: YAML Workspace
Postby Kunda1 » Mon Feb 05, 2018 5:09 pm
debugging
NormandC
Re: YAML Workspace
Postby NormandC » Tue Feb 06, 2018 3:46 am
Hello mambix,
Just saying, it's not called a workspace in FreeCAD-speak, but a workbench. ;) Workbenches
microelly2
Re: YAML Workspace
Postby microelly2 » Tue Feb 06, 2018 6:37 am
Nice idea.
I have started an interpreter for a special syntax which merges yaml and the kivy language.
I called it miki. there are some improvements against yaml, so I can repeat keys
my idea was to have the same syntax for qt gui, part design and assembly and inventor scenes.
http://freecadbuch.de/doku.php?id=blog: ... g_erzeugen
https://kivy.org/docs/api-kivy.lang.html
mambix
Re: YAML Workspace
Postby mambix » Tue Feb 06, 2018 11:41 am
debugging
MacOS: I had to manually copy PyYAML files to FreeCAD's internal python2.7 to make it work.
mambix
Re: YAML Workspace
Postby mambix » Tue Feb 06, 2018 11:44 am
Hello mambix,
Ok, but I don't want to rename the whole thing again :lol:
As long as ppl find it useful no one cares right 8-)
mambix
Re: YAML Workspace
Postby mambix » Tue Feb 06, 2018 11:47 am
Nice idea.
Nice!
I need to add support for simple objects too. And I'm planning to add the option to specify STL files by URL so you can add objects that you can find models you can find on the web. Download and store them locally, next import just use the local stored copy of that model.
Comes handy when designing 3d printers and PC cases as you can import motherboard or GPU models to see how it fits.
NormandC
Re: YAML Workspace
Postby NormandC » Thu Feb 08, 2018 3:18 am
Some of us do care about consistency in naming.
But it's your work, you are free to do as you please.
