Work Feature workbench with parametric objects
rentlau_64
Re: Work Feature workbench with parametric objects
Postby rentlau_64 » Sun Mar 04, 2018 9:03 am
Hello all
I need Help to find a manner to reference my "CenterLinePoint" Object to a "BaseFeature" (if selected)
my code is :
class CenterLinePoint(WF_Point):
    """ The CenterLinePoint feature object. """
    # this method is mandatory
    def __init__(self,selfobj):
        self.name = "CenterLinePoint"
        WF_Point.__init__(self, selfobj, self.name)
        """ Add some custom properties to our CenterLinePoint feature object. """
        selfobj.addProperty("App::PropertyLinkSub","Edge",self.name,
                            "Input edge")
        selfobj.addProperty("App::PropertyInteger","NumberLinePart",self.name,
                            "The number of parts of parent segment !").NumberLinePart=2
        selfobj.addProperty("App::PropertyInteger","IndexPart",self.name,
                            "The location of the point : 1/2 means middle of the segment !").IndexPart=1
        selfobj.setEditorMode("Edge", 1)
        selfobj.Proxy = self
    def execute(self,selfobj):
And I get an error : "Link go out of the allowed scope" for the "CenterLinePoint" Object created.
Hereafter an illustration
OS: Ubuntu 17.10
Version: 0.17.13142 (Git)
Build type: None
Hash: b0928342309511026e713d1f4e26be65b5b297dc
Python version: 2.7.14
OCC version: 7.1.0
Locale: French/France (fr_FR)
Thank you for your help
Rentlau
realthunder
Postby realthunder » Wed Mar 07, 2018 11:15 pm
Hello all
Assuming you are not creating any cyclic references, simply change your PropertyLinkSub to PropertyLinkSubGlobal shall work. The reason for this message is because Body, being derived from geo feature group, demands all objects that reference its children being added to the group, too. So, by right, your CenterLinePoint object should be added to the Body (or App::Part) as well. You can use Global links to bypass that requirement.
On the other hand, you should realize that if you link to a children of a body without adding your object to the body as well, you'll have trouble getting the actual coordinate of the object.
rentlau_64
Postby rentlau_64 » Thu Mar 08, 2018 6:16 am
A new release is on line...
github :https://github.com/Rentlau/WorkFeature-WB
Thank very much you I will use this info for next release.
Rentlau
bill
Postby bill » Thu Mar 08, 2018 4:34 pm
rentlau_64
Postby rentlau_64 » Thu Mar 08, 2018 6:39 pm
Is there any value to add this workbench to /FreeCAD-addons ?
If yes feel free to do, i will be very please. :D :D
Rentlau_64
triplus
Postby triplus » Thu Mar 08, 2018 8:03 pm
Best place to request for Work Feature workbench to be added is here:
https://github.com/FreeCAD/FreeCAD-addons/issues
rentlau_64
Postby rentlau_64 » Thu Mar 08, 2018 9:38 pm
Triplus,
Thank you the request is done.
Rentlau_64
HarryGeier
Postby HarryGeier » Thu Mar 08, 2018 10:19 pm
Triplus,
Rentlau_64
Is it supposed to work in .17 now.. here still no luck.. cannot refer to the created elements, They are not in the active body, nor can i move them into it...
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
bill
Postby bill » Thu Mar 08, 2018 10:23 pm
I installed and see only this: :?
Should I be seeing all the FUNCTIONs of the old WF-macro ?
Selecting in the WB-mode will be nicer than the cramped panel-mode!
I am using FC-Daily: Git version 13375; just FYI!
triplus
Postby triplus » Fri Mar 09, 2018 12:50 am
Triplus,
Rentlau_64
Great. Note that is could take a few days.
Likely this wasn't tackled yet in Work Feature workbench. In addition i feel that some general guidelines or/and discussion about this area is still missing and will need to happen in the future.
I bit of patience will likely be needed to get to that goal. ;)
Both approaches have some pros and cons. Workbench approach for example should for one improve the customization potential. More standard workflow and install and usage experience is expected too. Parametric objects ...
