Work Feature workbench with parametric objects
mario52
Re: Work Feature workbench with parametric objects
Postby mario52 » Sun Mar 18, 2018 1:22 pm
hi
no problem
rentlau_64 wrote:
Sun Mar 18, 2018 7:10 am
Get the archive from Git :https://github.com/Rentlau/WorkFeature-WB
And unzip into your home directory /home/your_rname/.FreeCAD/Mod/
WorkFeature (macro)
WorkFeature-WB (workbench)
Version: 0.17.13387 (Git)
Hash: c5f4079252b11e3c54cd603be7d3697fa9f9d922
Python version: 2.7.14
OCC version: 7.1.0
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
i prefer WorkFeature (macro) always available, always on hand, thanks rentlau_64
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
rentlau_64
Postby rentlau_64 » Sun Mar 18, 2018 8:08 pm
Hi, GlouGlou
I Tested the installation on Windows 8 and didn't get any problem,
The Workbench is available on the Workbench Menu.
I unzip the file from Github under :
C:\Program Files\FreeCAD 0.16\Mod\WorkeFeature-WB-master
And few usage tests were positive too.
What is the exact procedure you followed to install?
Rentlau_64
GlouGlou
Postby GlouGlou » Sun Mar 18, 2018 8:17 pm
By copying manually the directory, its working now... sorry about that. ;)
yorik
Site Admin
Postby yorik » Mon Mar 19, 2018 4:04 pm
the workfeature WB is now part of the addons repo.
I had to make some git sorcery to rename the workfeature macro repo, tell me if you notice any problem.
rentlau_64
Postby rentlau_64 » Mon Mar 19, 2018 9:58 pm
Merci Yorik,
I will keep you inform if i detect some issue.
Have a nice day
Rentlau_64
hammax
Postby hammax » Fri Mar 23, 2018 9:36 am
...thanks, now the WorkfeatureWB is installable without problems via addonmanager
on (my) Win10-32 under FC.17.13429
and usable.
https://forum.freecadweb.org/viewtopic. ... 95#p217771
HarryGeier
Postby HarryGeier » Fri Mar 23, 2018 9:54 am
and usable.
How do you then bring them into a Sketch ??
i must select each object and import via shapebinder..
I tried to move all, set, objects .. into a body..no way...
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
rentlau_64
Postby rentlau_64 » Sun Mar 25, 2018 7:40 am
@ realthunder
Thank you for your trick regarding linksubglobal : It seems it fix my issue.
@ HarryGeier
I am currently fixing the "PartDesign Body" issue and hope to deliver soon a new fix.
What do you mean : You would like to transform the WF_WB parametric object into a Sketch object and keep the parametric behavior?
Thank you for your comment
Have a nice day
Rentlau_64
HarryGeier
Postby HarryGeier » Sun Mar 25, 2018 9:43 am
Sure.. what else should i want to do with them , other than reference them as external geometry in a sketch ?
Same as i do with datum_geometry of the elements from the workfeature_macro
rentlau_64
Postby rentlau_64 » Fri May 03, 2019 4:23 am
New release of the WorkFeature Workbench, compatible with Qt5 and py3 is now available here:
Enjoy ! :D
Rentlau
