Sketcher Auto Remove Redundants mode
abdullah
Postby abdullah » Wed Aug 29, 2018 6:54 pm
Hi! I have been away for a couple of months and I will still be for some time.
I had many notifications and messages, to which I will reply when I come back in about a month.
In the meantime, the "auto remove redundants" mode (you will find it next to the solver messages, a checkbox) have been merged.
It was quite a request to do something so that redundant creation did not get in the way while using the sketcher (specially when using the polyline creation tool). This was more painful after the sketcher solver improvements, as the sketcher was way much more picky than before. This new mode accommodates this request.
When an UI command (geometry creation, constraints, tools...) ends up in a situation detected by the solver as redundant, it automatically deletes the redundant constraints.
The checkbox is there so that you can disable it for cases when automatic removal is not desired.
Just give it a try and leave some feedback for when I come back to coding :)
Re: Sketcher Auto Remove Redundants mode
Postby chrisb » Wed Aug 29, 2018 10:52 pm
Thanks for the update. And: You are back when you are back.
abdullah
Postby abdullah » Mon Sep 24, 2018 5:44 pm
Hi chris!
Have you given it a go this feature? Any feedback?
Postby chrisb » Mon Sep 24, 2018 7:24 pm
No issues so far! I have tested it and it worked es designed, but I have to confess that I am in the comfortable situation where I can avoid redundant constraints - especially after having written some 70 pages about sketches. I will provoke redundancies for further tests.
abdullah
Postby abdullah » Tue Sep 25, 2018 12:08 pm
Yup! I have seen you sketcher LateX quest ;)
Of course, if you know how not to get in trouble, that helps.
I have found it specially helpful when applying symmetric constraints. May times, today's solver detects previously introduced horizontal or vertical constraints redundant.
Let me know your findings :)
schupin
Postby schupin » Tue Sep 25, 2018 8:33 pm
+1 !
This addition saved me a lot of mouse clicks recently.
All the recent improvement on the sketcher are very nice done abdullah !
