Arch Texture Workbench
bitacovir
Re: Arch Texture Workbench
Postby bitacovir » Sat Nov 03, 2018 10:05 pm
Good progress. Keep going!!
::bitacovir::
My Blog
Mini Airflow Tunnel Project
paullee
Postby paullee » Sat Nov 03, 2018 11:35 pm
Look much much better! :)
Looking forward to all new features here and there by all contributors make Arch/BIM more powerful and productive!
Maybe some day FC just directly output something that could show in a tablet / smartphone on webgl / glTF format - https://forum.freecadweb.org/viewtopic.php?f=8&t=31680
triplus
Postby triplus » Sat Nov 03, 2018 11:55 pm
Nice to see more advance texture support is coming to FreeCAD.
P.S. In both Py2 and Py3 FreeCAD builds i get No module named 'faceset_utils'. When trying to activate the workbench.
paullee
Postby paullee » Sun Nov 04, 2018 12:35 am
furti wrote:
Sat Nov 03, 2018 5:03 pm
It is possible now to rotate textures for individual faces.
The usage of the tool is documented at the end of the getting started guide.
Hi, by checking the Readme, it seems quite handy to do the rotation! :D
Not sure if there are a numbers of faces to tweak, any better way in the future.
In addition, is it something start to look similar to UV Mapping? I just have a little knowledge about that start learning something in Blender.
furti
Postby furti » Sun Nov 04, 2018 7:20 am
Thanks for the info. It worked for me in py3 but had the same message for py2. Have to look into this.
The major problem now is that you can't see what face has a special configuration from the gui. I needed a quick way to get things working. So i used command panels for configuration. The idea is to move away from command panels to a own tab like the spreadsheet does. Than there would be enough space to do a proper GUI :)
Some basic stuff like scaling (done by setting the length and width), rotation an maybe transition is mandatory. Because it is impossible to let a algorithm map all faces correctly. But itbis it is far away from a general texture mapping like blender has.
Edit: fixed a typo
furti
Postby furti » Sun Nov 04, 2018 10:44 am
This problem should be fixed now :)
furti
Postby furti » Sun Nov 04, 2018 11:20 am
Another good news. The texture mapping should work in Py2 builds also :)
Coin3D does not like "Unicode" objects for the filename. Had to encode it for Py2 builds to get a "str" object.
triplus
Postby triplus » Mon Nov 05, 2018 11:06 pm
I can confirm the issue was resolved (and thanks for creating the tutorial):
Nice for being able to set the texture and for the result to survive FreeCAD restart. As View -> Texture mapping ... only persist until you close FreeCAD. Anyway nice to see texture support and improvements are being tackled and good luck with your work.
I created the document on Py2 build and noticed the document won't be loaded successfully after:
<type 'exceptions.TypeError'>: string indices must be integers
P.S. The same document will load without issues on Py3 build.
furti
Postby furti » Tue Nov 06, 2018 4:00 pm
This should be fixed now. Checked a variable for type 'str' but Py 2 gave me 'unicode' :roll: Now the check works and the file is loaded in Python 2 correctly :)
furti
Postby furti » Wed Nov 07, 2018 4:51 pm
The workbench is now available from the addon manager :)
