Arch Texture Workbench
triplus
Re: Arch Texture Workbench
Post by triplus »
furti wrote: Tue Nov 06, 2018 4:00 pm
triplus wrote: Mon Nov 05, 2018 11:06 pm <type 'exceptions.TypeError'>: string indices must be integers
This should be fixed now. Checked a variable for type 'str' but Py 2 gave me 'unicode' :roll: Now the check works and the file is loaded in Python 2 correctly :)
Can confirm that the test file i created (image above) opens now without the mentioned issue in both Py2 and Py3 builds.
The workbench is now available from the addon manager :)
Good to hear that.
furti
Post by furti »
A new feature is available now. It is possible to define envrionment textures (Ground, Sky, Panorama) in the Scene. This might be a easy way to enhance screenshots of architectural object (or even other objects too. Maybe you find other use cases for this feature :D )
The documentation is available in the Readme of the Workbench (https://github.com/furti/FreeCAD-ArchTextures)
When adding a Environment config you can create something like this:
Kept the Navigation Cube in the screenshot on Purpose. So that it is clear this screenshot was made directly from FreeCAD ;)
Hope you can make some use out of it :)
Best Regards
Daniel
Post by Kunda1 »
furti wrote: Thu Nov 15, 2018 5:03 pm
Nice!
Would you consider using github tags when adding new features?
triplus
Post by triplus »
Should Ground Image adapt when changing the Geometry parameters? As Panorama and Sky Images do. Based on the documentation i guess Ground Image shouldn't adapt. But i am guessing it would be nice to have control of its size?
paullee
Post by paullee »
Thanks for adding another exciting and very useful feature!
Can't wait to read the doc but do not have chance to use ( on the road).
Potential to use panoramic map (not sure the exact term) e.g in Google map? - something can ne used in Blender.
furti
Post by furti »
Kunda1 wrote: Thu Nov 15, 2018 5:13 pm using github tags
Sure. No problem to do this :)
triplus wrote: Thu Nov 15, 2018 11:59 pm Should Ground Image adapt when changing the Geometry parameters
You are right. Normally it should update. Forgot to update the coordinates when the geomezry coordinates change. Thanks for the hint :)
paullee wrote: Fri Nov 16, 2018 1:17 amGoogle map
Don't know exactly what you mean maybe you can give an example of how this might look?
paullee
Post by paullee »
furti wrote: Fri Nov 16, 2018 6:06 am ]
Should be equirectangular-panoramic (equirect-pano) image.
furti
Post by furti »
triplus wrote: Thu Nov 15, 2018 11:59 pm Should Ground Image adapt when changing the Geometry parameters?
Version 0.2 fixes the problem and the size of the ground plane is updated (https://github.com/furti/FreeCAD-ArchTe ... es/tag/0.2)
paullee wrote: Sat Nov 17, 2018 5:31 am Should be equirectangular-panoramic
At first I tried to use this Coin3D node: https://grey.colorado.edu/coin3d/classS ... round.html
But I couldn't get it to do anything. I think such things must be implemented directly in Coin3D (if not already there). But this is Nothing I can do Right now (I don't know much about Coin3D or C++). :)
triplus
Post by triplus »
furti wrote: Mon Nov 19, 2018 3:18 pm Version 0.2 fixes the problem and the size of the ground plane is updated (https://github.com/furti/FreeCAD-ArchTe ... es/tag/0.2)
Can confirm it now adapts to changed values. Thanks.
paullee
Post by paullee »
Thanks! Hope this could can achieve later!
Locked
