Arch Texture Workbench
bitacovir
Re: Arch Texture Workbench
Postby bitacovir » Sun Jun 09, 2019 2:00 pm
paullee wrote:
Sat Jun 08, 2019 6:49 pm
Looks great !
The only feature missing to compete with something SketchUp is shadow I would argue? :)
Ideally, an ambient occlusion effect.
::bitacovir::
My personal web site
My old Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Sun Jun 09, 2019 4:58 pm
buffer shadows are supported by coin. Only needs to implement it... An ambient occlusion not, but coin supports GLSL IIRC. So in theory, anything the GPU can do by itself is possible...
bitacovir
Postby bitacovir » Mon Jun 10, 2019 8:09 pm
I mean, something to visualize the volume of the geometries. Because when you apply the texture and turn off the lines, the image is too flat.
::bitacovir::
My old Blog
yorik
Site Admin
Postby yorik » Tue Jun 11, 2019 9:10 pm
yes, I also like the AO they have in revit... In any case, it's definitely possible to do AO in GLSL: https://martinkschroder.wordpress.com/2 ... -and-glsl/
furti
Postby furti » Wed Jun 12, 2019 5:05 am
I also think it is possible to do.
I read this article https://learnopengl.com/Advanced-Lighting/SSAO
It gives a pretty good explanation on how ssao works.
I think the fragment shader in coin3d is the place to implement this. But foes coin3d use deferred rendering? So that we have the needed information available?
And the openinventor mentor states that a fragment shader replaces a lot of built in functionality like texture rendering and stuff. So this has to be reimplemented in the shader i think :?:
furti
Postby furti » Thu Jun 13, 2019 7:09 pm
sgrogan wrote:
Fri Jun 07, 2019 10:15 pm
furti wrote:
Fri Jun 07, 2019 5:03 am
Will try to figure this out and document it :)
Thanks, cool looking work!
Hard to tell what is really supported. Based on the documentation of coin3D it depends on the installed simage library.
https://grey.colorado.edu/coin3d/classS ... 9b068a5f49
But as this is outdated. And this is a simage library in coin3D itself: https://bitbucket.org/Coin3D/simage/src/default/src/ I would assume the following is supported:
- xwd
- tiff
- tga
- png
- pic
- jpeg
- JPEG-2000
- gif
- rgb
- eps
But maybe someone knows what simage library FreeCAD uses?
bitacovir
Postby bitacovir » Fri Jun 14, 2019 10:44 pm
One question. Is it possible to give the option of rotation of the texture picture when is used repeatedly to cover a surface? This way you can mitigate the repetitive patterns.
::bitacovir::
My old Blog
furti
Postby furti » Sat Jun 15, 2019 4:19 am
This is not possible at the moment. But this isva nice feature request. I will have a look how this could be implemented.
For now i always used seamless textures. So there is no visible seam.
sgrogan
Postby sgrogan » Sat Jun 15, 2019 4:07 pm
For Win and the Conda based builds I believe its 1.7
triplus
Postby triplus » Wed Jun 19, 2019 9:29 pm
Nice progress!
