SQL Reporting Workbench for FreeCAD
Re: SQL Reporting Workbench for FreeCAD
Postby chrisb » Mon Feb 25, 2019 12:12 am
wandererfan wrote:
Fri Feb 22, 2019 9:44 pm
Reports go onto TechDraw pages easily!
Very interesting application.
roerich_64
Postby roerich_64 » Thu Mar 14, 2019 10:24 am
Realy!
I will give the Reporting WB a try at the house_B ;)
But it needs a little time to do that ;)
BR
Walter
romabalti1900
Postby romabalti1900 » Wed Apr 17, 2019 12:18 pm
VERY COOL Workbench !
HolgerL
Postby HolgerL » Thu Dec 05, 2019 2:51 pm
Hi furti,
thank you very much for your great tool!
You solved my problem with gernerating a BOM including size of all components.
Great work!
Holger
Postby Kunda1 » Thu Dec 05, 2019 3:14 pm
Can you post your own success story with this WB in this forum for other to see ?
How did you generate the BOM ?
HolgerL
Postby HolgerL » Fri Dec 06, 2019 8:01 am
yes sure I can do that. But it is pretty simple and straight forward.
I have build the complete construction of the planning for a camper into freecad. So this is an assemby of "boxes", which are all the plates of the planned furniture. Then I looked for a solution to collect all these pieces with their length, width and heights to calculate the total amount of wood I need and so get the total weight of the interior construction.
So I found this reporting workbench and put the reporting statement:
SELECT  Label, Length, Width, Height
FROM document
WHERE Length IS NOT NULL
This gives a result table like:
=Label	Length	Width	Height
Boden	=3600mm	=2040mm	=52mm
Seite links	=3600mm	=40mm	=2192mm
Seite rechts	=3600mm	=40mm	=2192mm
Seite hinten	=40mm	=2040mm	=1960mm
Seite vorne	=40mm	=2040mm	=1500mm
Seite Alkoven Top	=40mm	=2040mm	=670mm
Sitz_Wand001	=16mm	=650mm	=634mm
Sitz_Wand002	=16mm	=650mm	=634mm
Bodenplatte Sitz	=800mm	=660mm	=16mm
Sitz_Wand_L	=800mm	=16mm	=634mm
Sitz_Wand_R	=800mm	=16mm	=634mm
Sitz_Trennwand	=16mm	=1960mm	=634mm
This I then took to Excel and made some calculations.
- removed the mm and make the fields number
- filtered Length,Width,Height for 16mm entries, because these are the furniture plates. (40mm are the sidewalls..) and gave them a 4. filter attribute
- for all these furniture entries I simply calculated the volume and devided by 16 to get the total plate area. done
Sure this could be some more automated, but since this is more a singel event caculation it is ok for me to get the result.
stanicke
Postby stanicke » Wed Dec 25, 2019 8:56 pm
Hello, I needed an export to a .xlsx file, so I implemented it, can be useful to somebody :). See https://github.com/furti/FreeCAD-Reporting/pull/26
One idea for improvement: the xlsx file is able to handle units as a cell format, but I am not sure how to get proper units from FreeCad :(
Joyas
Postby Joyas » Thu Dec 26, 2019 2:57 am
This workbench is interesting.
What happens if accidentally I write "DELETE FROM document" without specifying anything (WHERE)?
Does it clean the entire FreeCAD document?
:P
Estudié ingeniería técnica industrial en España y sólo me ha servido para estar en el paro, no me contratan porque no tengo experiencia, y no tengo experiencia porque no me contratan. No debí estudiar esa carrera.
Postby chrisb » Thu Dec 26, 2019 9:02 am
There are several possibilities to find out:
- You can read the documentation and find out that it is not implemented: https://github.com/furti/FreeCAD-Reporting
- You can look at the source code: https://github.com/furti/FreeCAD-Reporting
- You can even try it, of course on a copy if the document is important..
stanicke
Postby stanicke » Thu Dec 26, 2019 12:22 pm
Ok, I also added proper cell formatting, so cell values can be now used directly for further computations in Excel (see https://github.com/furti/FreeCAD-Reporting/pull/26)
