SQL Reporting Workbench for FreeCAD
mario52
Re: SQL Reporting Workbench for FreeCAD
Postby mario52 » Fri Dec 27, 2019 10:32 am
hi
HolgerL wrote:
Fri Dec 06, 2019 8:01 am
- removed the mm and make the fields number
- filtered Length,Width,Height for 16mm entries, because these are the furniture plates. (40mm are the sidewalls..) and gave them a 4. filter attribute
- for all these furniture entries I simply calculated the volume and devided by 16 to get the total plate area. done
try also this macro, you split like you want Macro_FCTreeView Image but FreeCAD version 0.17 no yet upgraded
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
dcapeletti
Postby dcapeletti » Sun Feb 16, 2020 7:15 pm
furti wrote:
Sat Jan 12, 2019 11:02 am
Columns
Columns is a comma separated list of properties you want in the result for each object.
* is a special property that returns the whole object instead of a single property. This might be useful when you want to perform certain operations on some objects in python. You can select them with a select statement, and process them afterwards.
When you use a function (Sum, Min, Max, Count) here, only a single row will be returned with the function applied to each object. You can not mix single Properties and functions. But it should be possible to use multiple functions in a single select statement.
Hello, if I add a new property to the object called Provider, can I access it by means of an sql instruction? How can I do it?
select Provider from document where Name = 'Box'
select Base_Provider from document where Name = 'Box'
None of the above instructions work.
Thanks
furti
Postby furti » Mon Feb 17, 2020 6:01 am
You mean the property is called "Provider"?
If so, the first query should work.
What is the problem with the query?
dcapeletti
Postby dcapeletti » Mon Feb 17, 2020 5:44 pm
It's a dynamic property that I add to the object myself.
Attached is a sample video https://www.youtube.com/watch?v=g3Bs_jz ... e=youtu.be
The first query does not throw an error but no result is shown, in the second query, the next error is thrown.
ERROR:root:
  File "/home/dcapeletti/.FreeCAD/Mod/Reporting/report.py", line 352, in __init__
    self.statement = SQL_PARSER.parse(plainTextStatement)
  File "/home/dcapeletti/.FreeCAD/Mod/Reporting/sql/sql_parser.py", line 1149, in parse
    sqlStatement = sql_grammar.parse(sqlString, actions=ParserActions())
  File "/home/dcapeletti/.FreeCAD/Mod/Reporting/sql/sql_grammar.py", line 1958, in parse
    return parser.parse()
  File "/home/dcapeletti/.FreeCAD/Mod/Reporting/sql/sql_grammar.py", line 1942, in parse
    raise ParseError(format_error(self._input, self._failure, self._expected))
  File "<string>", line None
sql.sql_grammar.ParseError: Line 1: expected [a-zA-Z0-9\.], [ \t\r\n], [ \t\r\n], ","
Select Label, Base_Provider from document where Name = 'Box'
But as shown in the spreadsheet, through Box.Base_Provider I can recover the data without any problem.
Greetings
furti
Postby furti » Tue Feb 18, 2020 9:07 am
Now I can see what is wrong here. The character _ is not allowed in Property names right now. I created a Issue for this. https://github.com/furti/FreeCAD-Reporting/issues/27
Is it possible that you rename the Property to something Alphanumeric like "BaseProvider" instead of "Base_Provider"?
dcapeletti
Postby dcapeletti » Tue Feb 18, 2020 12:39 pm
Hello, the query works correctly if I create the property but do not add it to any group, as shown in the image. That way if you can access it directly with Provider, but if I add it to a group, FreeCAD adds the group name separated by _.
Group property.png (16.37 KiB) Viewed 538 times
dcapeletti
Postby dcapeletti » Wed Feb 19, 2020 9:01 pm
I think this project is very powerful when it comes to creating reports and not only that, but using object manipulation instructions via the freecad API using SQL directly. :)
