Gesture navigation style updates (may 2019)
Re: Gesture navigation style updates (may 2019)
Postby chrisb » Fri Jun 14, 2019 11:18 pm
This looks better:
0(40,605)
0(40,605)
0(40,605)
0(40,605)
0(40,605)
0(40,605)
0(40,605)
Gesture start SoGesturePinchEvent(-338,707)
 -> GestureState
Gesture end SoGesturePinchEvent(-338,707)
 -> IdleState
During the 0(40,605) outputs it zooms correctly (or vice versa). If I end zooming The camera position jumps and I get the three "Gesture" outputs.
DeepSOIC
Postby DeepSOIC » Sat Jun 15, 2019 12:15 am
0(blah,blah) looks like mouse wheel events are coming. It looks like gesture events are not properly generated, so it's probably best to make FreeCAD ignore them altogether on MacOS.
Postby chrisb » Sat Jun 15, 2019 7:59 am
For zooming I use two fingers on the touchpad. Move them up is zooming out, moving down is zooming in. All this happens on the 0(blah,blah) events. Please don't disable them too :), the rest can well be ignored, as far as I am concerned.
DeepSOIC
Postby DeepSOIC » Sat Jun 15, 2019 8:19 am
Does anything happen if you pinch instead, as if the touchpad is a touchscreen?
Postby chrisb » Sat Jun 15, 2019 9:10 am
Yes, the zoomed object moves immediately at the lower right corner out of sight, in the same way as it did before after finishing zooming.
Output:
Gesture start SoGesturePinchEvent(186,524)
 -> GestureState
Gesture data SoGesturePinchEvent(186,524)
Gesture end SoGesturePinchEvent(186,524)
 -> IdleState
Gesture start SoGesturePinchEvent(-378,838)
 -> GestureState
Gesture end SoGesturePinchEvent(-378,838)
 -> IdleState
DeepSOIC
Postby DeepSOIC » Sat Jun 15, 2019 12:46 pm
So I looked at the code, and it's probably the double start event that is causing a problem. I have for some reason commented out the ignoring of extra start events (don't remember why I did, possibly as an attempt to fix some early bug), now I wonder if I can uncomment it and it fixes the problem... I'll experiment later, i'm overloaded right now.
Postby Kunda1 » Sat Jun 15, 2019 2:37 pm
quick question: should we open a ticket to track this ?
DeepSOIC
Postby DeepSOIC » Sat Jun 15, 2019 2:45 pm
Why not? ;)
Postby Kunda1 » Sat Jun 15, 2019 6:13 pm
Why not? ;)
@chrisb are these 2 separate issues? or all one?
Postby chrisb » Sat Jun 15, 2019 8:57 pm
It's all in one.
