Addon Manager improvements
Syres
Re: Addon Manager improvements
Postby Syres » Tue Jun 18, 2019 10:51 am
Ignore the above post, I was on the right track but it's not the length of the Github URL but the length of 'storename'. If I change the addonmanager_workers.py around line 414 from:
                    storename = os.path.join(store,name)
                    if not os.path.exists(storename):
to the hack of:
                    storename = storename[:259]
the Reinforcement Wb images load correctly, the 2nd image full path had a length of 261 characters.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17065 (Git)
Hash: d890b4ec17b9030dc2933c029debb2a655a08218
Python version: 3.6.8
Qt version: 5.12.1
Postby Kunda1 » Tue Jun 18, 2019 10:54 am
Nice :tada:
What does
do ?
Syres
Postby Syres » Tue Jun 18, 2019 11:01 am
What does
do ?
It's the equivalent of Vb's Left string function so only the first 259 characters are used and the rest dropped, hence the word hack!! I can look at a proper fix but I'm concerned about how much of Yorik's fine work will be altered so I'd like to wait for further feedback beforehand.
easyw-fc
Postby easyw-fc » Tue Jun 18, 2019 4:41 pm
yorik wrote:
Sun Jun 16, 2019 2:55 am
@Kunda1 and everybody else, if any of you add new icons, please also update this file: https://github.com/FreeCAD/FreeCAD/blob ... anager.qrc
Hi @yorik @kunda
I see that I have my WB icon in the file:
<file>icons/Kicad-StepUp-tools-workbench_icon.svg</file>
but it seems it is not loaded... is it because there are '-' inside the icon name?
Manipulator and defeaturing wb get the icon just fine...
Postby Kunda1 » Tue Jun 18, 2019 5:01 pm
I don't know the logic @yorik used, but can you quickly convert it locally and test it ? (maybe needs a restart?)
Syres
Postby Syres » Tue Jun 18, 2019 5:46 pm
In order to reduce the chances of duplicate filenames with those images greater than the Windows limit, my suggestion is to use the workbench name in conjunction with a bit of maths to arrive at a new 'storename'.
So my suggestion would be to change the section in addonmanager_workers.py at line 385 from:
        l = self.loadImages( message, self.repos[self.idx][1])
        if l:
            self.info_label.emit( l )
        self.stop = True
    def loadImages(self,message,url):
        "checks if the given page contains images and downloads them"
        # QTextBrowser cannot display online images. So we download them
        # here, and replace the image link in the html code with the
        # downloaded version
        imagepaths = re.findall("<img.*?src=\"(.*?)\"",message)
        if imagepaths:
            storedimages = []
            store = os.path.join(FreeCAD.getUserAppDataDir(),"AddonManager","Images")
            if not os.path.exists(store):
                os.makedirs(store)
            for path in imagepaths:
                origpath = path
                if "?" in path:
                    # remove everything after the ?
                    path = path.split("?")[0]
                if not path.startswith("http"):
                    path = getserver(url) + path
                name = path.split("/")[-1]
                if name and path.startswith("http"):
to:
        l = self.loadImages( message, self.repos[self.idx][1], self.repos[self.idx][0])
        if l:
        self.stop = True
    def loadImages(self,message,url,wbName):
        if imagepaths:
            storedimages = []
                os.makedirs(store)
                origpath = path
                if "?" in path:
                    if len(storename) >= 260:
                        remainChars = 259 - (len(store) + len(wbName) + 1)
                        storename = os.path.join(store,wbName+name[-remainChars:])
I've done quite a bit of testing but if anyone else wants to give it a try (modified file attached) or if there's a much more slick solution to try then I can test.
(29.13 KiB) Downloaded 24 times
sgrogan
Postby sgrogan » Tue Jun 18, 2019 9:35 pm
Thanks, this work for Reinforcement.
This leaves me with only 2 WB's with problems;
SlopedPlanesMacro
Report View error
AddonManager: Debug: Error retrieving image from https://github.com/caceres/SlopedPlanesMacro/raw/master/SlopedPlanes.png
github repo link from FreeCAD/addons repo https://github.com/luzpaz/SlopedPlanesM ... 65b662961f
Notice luzpav vs. caceres
Link to the only image in the README.md https://user-images.githubusercontent.c ... c10626.png
WebTools
Report View error
AddonManager: Debug: Error retrieving image from https://camo.githubusercontent.com/9028281cd466416a12cac844af789d1e7c193dc3/68747470733a2f2f7777772e667265656361647765622e6f72672f77696b692f696d616765732f662f66382f5765625f536b657463686661622e706e67
github repo link from FreeCAD/addons repo https://github.com/yorikvanhavre/WebToo ... 4c21fefed5
Notice camo
TIA to all testing.
Link to first image in the README.md https://camo.githubusercontent.com/ba8a ... 742e706e67
"fight the good fight"
nic
Postby nic » Wed Jun 19, 2019 6:51 am
Today's upgrade for FC0.19 (ubuntu 18.10 PPA) disables addon manager :
During initialization the error No module named 'AddonManager_rc' occurred in /usr/share/freecad-daily/Mod/AddonManager/InitGui.py
Please look into the log file for further information
It indeed misses AddonManager_rc.py and I cannot find this module from github.
OS: Ubuntu 18.10 (i3/i3)
Version: 0.19.
Qt version: 5.11.1
Locale: French/Switzerland (fr_CH)
% apt-cache policy freecad-daily
freecad-daily:
  Installé : 0.19~pre1~201906182121~ubuntu18.10.1
  Candidat : 0.19~pre1~201906182121~ubuntu18.10.1
 Table de version :
 *** 0.19~pre1~201906182121~ubuntu18.10.1 500
        500 http://ppa.launchpad.net/freecad-maintainers/freecad-daily/ubuntu cosmic/main amd64 Packages
        500 http://ppa.launchpad.net/freecad-maintainers/freecad-daily/ubuntu cosmic/main i386 Packages
        100 /var/lib/dpkg/status
Syres
Postby Syres » Wed Jun 19, 2019 10:21 am
To allow the other images with correct target URLs to load I removed the 'return None' around line 426 (obviously the incorrectly targeted images still need to created the Debug Error) so from:
                        except:
                            print("AddonManager: Debug: Error retrieving image from",path)
                            return None
                        else:
to:
                        except:
                        else:
I also added an attempt to open Readme.md as well as README.md.
Edit: I've updated the post from yesterday evening with the latest addonmanager_workers.py to include the above changes.
Postby Kunda1 » Wed Jun 19, 2019 2:30 pm
Awesome, do you have these edits in a git branch that we can easily make a Pull Request from ?
