Air Plane Design Workbench - discussion thread
a179308
Re: Air Plane Design Workbench - discussion thread
Postby a179308 » Sun Jan 05, 2020 7:06 pm
I created this topic https://forum.freecadweb.org/viewtopic. ... 06#p358106 to avoid technical discussions in the topic "Announcements & Features".
Fred
a179308
Postby a179308 » Sun Jan 05, 2020 7:42 pm
Will_C wrote:
Sun Jan 05, 2020 11:58 am
Hi Fred,
I would have two questions regarding your WB.
1) What is the intent of the property "Rib Profil" which i circled in the attached Picture?
I can change the profile by typing in a new number in the section "Naca Profil".
Is Rib Profil only necessary if I want to use a DAT file?
2) Is it possible to select and/or attach the rib geometry to a vertex?
When I create a rib it just appears at a random point and I didn't find a way to set the origin during creation.
It would be helpful if I could fix the leading edge of the rib to a parametric vertex.
BR,
Will
Hello Will,
I created a topic in the open discussion forum to avoid technical discussions in the topic Announcements & Features.
the answer is here : https://forum.freecadweb.org/viewtopic. ... 39#p358139
Fred
