DXF - 3D-Solid import
apeltauer
Re: DXF - 3D-Solid import
Postby apeltauer » Tue May 19, 2020 5:44 pm
I had the same problem:
Some errors were found that prevent to install this workbench: Missing python module: xlutils, Missing python module: xlrd, Missing python module: xlwt, Missing python module: olefile , . Please install the missing components first.
What i did is to get the packages via pip.
I went to the bin folder where python.exe is located (same folder where FreeCAD.exe is located), then i used the following:
python.exe -m pip install xlutils
Doing this for the other packages as well. Make sure you have write permission!
jmplonka
Postby jmplonka » Wed May 20, 2020 7:24 am
Another attempt:
  1. run FreeCAD with administration privileges.
  2. open FreeCAD's python console and enter:
    import subprocess
    subprocess.call("python.exe -m pip install olefile")
    subprocess.call("python.exe -m pip install xlwt")
    subprocess.call("python.exe -m pip install xlrd")
    subprocess.call("python.exe -m pip install xlutils")
  3. restart FreeCAD
yorik
Site Admin
Postby yorik » Wed May 20, 2020 8:04 am
This is interesting... Would anyone have a sample DXF file with an ACIS solid inside? I'd like to test how to identify it and how our DXF importer could use the InventorPlugin if available...
jmplonka
Postby jmplonka » Wed May 20, 2020 8:10 am
Roy_043 attached one in his bug-reports: Reading DXF file:
  1. importerDXF.read(filename) # file of the DXF that contains 3D-Solids
  2. importerDXF.create3dModel(group, doc) # group the group object (maybe None for root element) in the doc (e.g. FreeCAD.getDocument(docname))
kisolre
Postby kisolre » Wed May 20, 2020 8:33 am
Here it worked even without this.
In one of the files I get the following error:
Importing: C:/Users/Wivern/AppData/Roaming/FreeCAD/Mod/InventorLoader/Demo-Status/Demo-Status-0.4.2.ipt
    created with Autodesk Inventor 2015 SP2 (Build 190223200, 223)
 7: '2ndf4cbxltchc12ouyxn3mibnb' ('PmBrowserSegment')
    NO READER DEFINED FOR PmBrowserSegment 'PmBrowserSegment'
 8: '5d5xv3ga6qwy3f6emf2jk5fhbj' ('PmAppSegment')
    NO READER DEFINED FOR PmAppSegment 'PmAppSegment'
 9: 'bs6eamaw2oin4ji1vd23znm1bp' ('PmBRepSegment')
    NO READER DEFINED FOR PmBRepSegment 'PmBRepSegment'
10: 'e5egmocggicavdjamfludnuwnf' ('PmResultSegment')
    NO READER DEFINED FOR PmResultSegment 'PmResultSegment'
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerSegment.py", line 578, in HandleBlock
    i = readType(node)
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerSegment.py", line 649, in Read_F645595C
    txt, ignore = getText8(node.data, i, 15) # 'ACIS BinaryFile' or from 20214 on 'ASM BinaryFile4'
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerUtils.py", line 711, in getText8
    txt = data[i: end].decode(ENCODING_FS)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 5: invalid start byte
11: 'itgitbhiz6t5uems4o2qoweina' ('NBNotebookSegment')
    NO READER DEFINED FOR NBNotebookSegment 'NBNotebookSegment'
12: 'snk62ndlbh5pahct4qy66rg1jd' ('PmGraphicsSegment')
    NO READER DEFINED FOR PmGraphicsSegment 'PmGraphicsSegment'
13: 'sq2ififzcxb4fg1qes6xlmynfm' ('DesignViewSegment')
    NO READER DEFINED FOR DesignViewSegment 'DesignViewSegment'
14: 'trf4ijcnldyb6jcuvg6lae32jm' ('PmDCSegment')
    NO READER DEFINED FOR PmDCSegment 'PmDCSegment'
Reading: C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\Demo-Status\Demo-Status-0.4.2.ipt
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerIL.py", line 108, in insert
    open(filename, skip, only, root)
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerIL.py", line 121, in open
    reader = read(doc, filename, True)
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerIL.py", line 40, in read
    if (Import_IPT.read(doc, filename, readProperties)):
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\Import_IPT.py", line 138, in read
    ole = setInventorFile(filename)
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerUtils.py", line 938, in setInventorFile
    setDumpFolder(_inventor_file)
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerUtils.py", line 894, in setDumpFolder
    cleanDumpFolder()
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\importerUtils.py", line 884, in cleanDumpFolder
    os.unlink(p)
<class 'PermissionError'>: [WinError 32] Процесът не може да направи обръщение към файла, защото той се използва от друг процес: 'C:\\Users\\Wivern\\AppData\\Roaming\\FreeCAD\\Mod\\InventorLoader\\Demo-Status\\Demo-Status-0.4.2_ipt\\PmDCSegment.log'
With Demo-Status-0.6.ipt I get this:
Reading: C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\Demo-Status\Demo-Status-0.6.ipt
	'Inventor Document Summary Information': (LC = 407)
	'Design Tracking Properties': (LC = 407)
	'_Private Model Information': (LC = 407)
	'Design Tracking Control': (LC = 407)
	'Inventor User Defined Properties': (LC = 407)
	'Inventor Summary Information': (LC = 407)
 1: '3gm2w4dvgmdkaow1ef6m6qj2bj' ('PmBRepSegment')
 2: 'bckpdcgie6iffzsnnye1ak2gjj' ('PmGraphicsSegment')
 3: 'emt5dzgmqvhsuxayvjdvwqxtbe' ('DesignViewSegment')
 4: 'iatxnwa14bribrqgeakdortknk' ('NBNotebookSegment')
 5: 'joanh4duwkq1ztk642dvql3xfd' ('PmBrowserSegment')
 6: 'ksr4rkghtutv2hjeurmgvaqjbb' ('PmResultSegment')
 7: 'leuwg1ezsox4dkk1fsofta24fp' ('PmDCSegment')
 8: 'px4nd4fy54o6jmhx352t5hpwnm' ('PmAppSegment')
Dumped data to folder: 'C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\InventorLoader\Demo-Status\Demo-Status-0.6_ipt'
    adding parameters table...
        A2='d18'; B2='=0.25'; C2='0.25mm'; D2='NOMINAL'
        A3='d19'; B3='=0.10000000000000002'; C3='0.1mm'; D3='NOMINAL'
        A4='d20'; B4='=0.25'; C4='0.25mm'; D4='NOMINAL'
        A5='d21'; B5='=180.0'; C5='180°'; D5='NOMINAL'
        A6='d22'; B6='=10.0'; C6='10mm'; D6='NOMINAL'
        A7='d23'; B7='=3.0000000000000004'; C7='3mm'; D7='NOMINAL'
        A8='d24'; B8='=4.9'; C8='4.9'; D8='NOMINAL'
        A9='d25'; B9='=2.5'; C9='2.5°'; D9='NOMINAL'
        A10='d26'; B10='=90.0'; C10='90°'; D10='NOMINAL'
        A11='d27'; B11='=90.0'; C11='90°'; D11='NOMINAL'
        A12='d28'; B12='=0.0'; C12='0°'; D12='NOMINAL'
        A13='d29'; B13='=0.0'; C13='0°'; D13='NOMINAL'
        A14='d33'; B14='=0.25'; C14='0.25mm'; D14='NOMINAL'
        A15='d34'; B15='=0.10000000000000002'; C15='0.1mm'; D15='NOMINAL'
        A16='d35'; B16='=0.25'; C16='0.25mm'; D16='NOMINAL'
        A17='d36'; B17='=10.0'; C17='10mm'; D17='NOMINAL'
        A18='d37'; B18='=3.2000000000000006'; C18='3.2mm'; D18='NOMINAL'
        A19='d38'; B19='=4.8'; C19='4.8'; D19='NOMINAL'
        A20='d39'; B20='=2.5'; C20='2.5°'; D20='NOMINAL'
        A21='d40'; B21='=90.0'; C21='90°'; D21='NOMINAL'
        A22='d41'; B22='=90.0'; C22='90°'; D22='NOMINAL'
        A23='d42'; B23='=0.0'; C23='0°'; D23='NOMINAL'
        A24='d43'; B24='=0.0'; C24='0°'; D24='NOMINAL'
        A25='d44'; B25='=180.0'; C25='180°'; D25='NOMINAL'
        A26='d48'; B26='=0.5'; C26='0.5mm'; D26='NOMINAL'
        A27='d50'; B27='=4.0'; C27='4mm'; D27='NOMINAL'
        A28='d51'; B28='=0.10000000000000002'; C28='0.1mm'; D28='NOMINAL'
        A29='d52'; B29='=0.10000000000000002'; C29='0.1mm'; D29='NOMINAL'
        A30='d53'; B30='=180.0'; C30='180°'; D30='NOMINAL'
        A31='d54'; B31='=10.0'; C31='10mm'; D31='NOMINAL'
        A32='d55'; B32='=2.5'; C32='2.5mm'; D32='NOMINAL'
        A33='d56'; B33='=5.42'; C33='5.42'; D33='NOMINAL'
        A34='d57'; B34='=14.999999999999998'; C34='15°'; D34='NOMINAL'
        A35='d58'; B35='=90.0'; C35='90°'; D35='NOMINAL'
        A36='d59'; B36='=90.0'; C36='90°'; D36='NOMINAL'
        A37='d60'; B37='=0.0'; C37='0°'; D37='NOMINAL'
        A38='d61'; B38='=0.0'; C38='0°'; D38='NOMINAL'
        A39='d62'; B39='=10.0'; C39='10mm'; D39='NOMINAL'
        A40='d63'; B40='=1.0'; C40='1mm'; D40='NOMINAL'
        A41='d64'; B41='=3.0'; C41='3'; D41='NOMINAL'
        A42='d65'; B42='=0.0'; C42='0°'; D42='NOMINAL'
        A43='d66'; B43='=90.0'; C43='90°'; D43='NOMINAL'
        A44='d67'; B44='=90.0'; C44='90°'; D44='NOMINAL'
        A45='d68'; B45='=0.0'; C45='0°'; D45='NOMINAL'
        A46='d69'; B46='=0.0'; C46='0°'; D46='NOMINAL'
        A47='d70'; B47='=0.25'; C47='0.25mm'; D47='NOMINAL'
        A48='d71'; B48='=0.10000000000000002'; C48='0.1mm'; D48='NOMINAL'
        A49='d72'; B49='=0.25'; C49='0.25mm'; D49='NOMINAL'
        A50='d73'; B50='=10.0'; C50='10mm'; D50='NOMINAL'
        A51='d74'; B51='=3.4250000000000003'; C51='3.425mm'; D51='NOMINAL'
        A52='d75'; B52='=5.25'; C52='5.25'; D52='NOMINAL'
        A53='d76'; B53='=5.0'; C53='5°'; D53='NOMINAL'
        A54='d77'; B54='=90.0'; C54='90°'; D54='NOMINAL'
        A55='d78'; B55='=90.0'; C55='90°'; D55='NOMINAL'
        A56='d79'; B56='=0.0'; C56='0°'; D56='NOMINAL'
        A57='d80'; B57='=0.0'; C57='0°'; D57='NOMINAL'
        A58='d81'; B58='=180.0'; C58='180°'; D58='NOMINAL'
        A59='d82'; B59='=0.25'; C59='0.25mm'; D59='NOMINAL'
        A60='d83'; B60='=0.10000000000000002'; C60='0.1mm'; D60='NOMINAL'
        A61='d84'; B61='=0.25'; C61='0.25mm'; D61='NOMINAL'
        A62='d85'; B62='=180.0'; C62='180°'; D62='NOMINAL'
        A63='d86'; B63='=10.0'; C63='10mm'; D63='NOMINAL'
        A64='d87'; B64='=3.3'; C64='3.3mm'; D64='NOMINAL'
        A65='d88'; B65='=5.25'; C65='5.25'; D65='NOMINAL'
        A66='d89'; B66='=2.5'; C66='2.5°'; D66='NOMINAL'
        A67='d90'; B67='=90.0'; C67='90°'; D67='NOMINAL'
        A68='d91'; B68='=90.0'; C68='90°'; D68='NOMINAL'
        A69='d92'; B69='=0.0'; C69='0°'; D69='NOMINAL'
        A70='d93'; B70='=0.0'; C70='0°'; D70='NOMINAL'
    adding 3D-Sketch '3D-Skizze1' ...
        ... added line (-0.1,0,0)-(-0.2,0.1,-0.3) False
        ... added line (0.1,0,0)-(0.2,-0.1,-0.3) False
        ... added line (-0.2,0,0.3)-(-0.3,-0.2,0.1) False
        ... added line (0.2,0,0.3)-(0.3,0.1,0.1) False
    adding 2D-Sketch 'Hand_Arm_R' ...
        ... added Arc-Circle M=(-1.00001,2.82686) R=0.25, from 3.141592653589793 to 0.0 ...
        ... added line (-0.750006,2.82686)-(-1.25001,2.82686) False = 1
        ... added Circle M=(-0.750006,2.66103) R=0.05...
        ... added line (-1.00001,2.82686)-(0,0) False = 3
Sketcher::setUpSketch()-T:0
Sketcher::Solve()-DogLeg-T:0
        ... added perpendicular constraint between lines 1 and 0
        ... added horizontal constraint to line 1
        ... added tangential constraint between Circle 0 and Circle 2
Sketcher::setUpSketch()-T:0.001
        ... added radius 'd18' = 0.25mm
        ... added diameter 'd19' = 0.1mm (r = 0.05000000000000001 mm)
    adding FxRevolve 'Hand_R' ...
    ... based on 'Hand_Arm_R' (full) ...
    adding FxCoil 'Arm_R' ...
        ... Feature 'Coil' not supported yet - trying SAT instead.
    adding 2D-Sketch 'Hand_Arm_L' ...
        ... added Arc-Circle M=(2.4495,-9.1995e-06) R=0.25, from 1.5707963267948966 to 4.7123889803846915 ...
        ... added line (2.4495,-0.250009)-(2.4495,0.249991) False = 1
        ... added line (2.4495,-9.1995e-06)-(-0.0126861,-9.1995e-06) False = 2
        ... added Circle M=(2.28367,-0.250009) R=0.05...
        ... added vertical constraint to line 0
        ... added perpendicular constraint between lines 1 and 2
        ... added tangential constraint between Circle 0 and Circle 3
        ... added diameter 'd34' = 0.1mm (r = 0.05000000000000001 mm)
    adding FxCoil 'Arm_L' ...
    adding FxRevolve 'Hand_L' ...
    ... based on 'Hand_Arm_L' (full) ...
    adding 2D-Sketch 'Head_Torso' ...
        ... added Arc-Circle M=(2.17465e-05,4) R=0.5, from 0.0 to 3.141592653589793 ...
        ... added line (2.17465e-05,4)-(0.500022,4) True = 1
        ... added line (0.500022,4)-(-0.499978,4) False = 2
        ... added Circle M=(1.00579,0) R=0.05...
        ... added Circle M=(1,1) R=0.05...
        ... added perpendicular constraint between lines 2 and 0
        ... added diameter 'd52' = 0.1mm (r = 0.04999999999999998 mm)
        ... added coincident constraint between Circle 0/1 and Line 1/2
        ... added coincident constraint between Circle 0/1 and Line 2/1
    adding FxRevolve 'Head' ...
    ... based on 'Head_Torso' (full) ...
    adding FxCoil 'Torso_U' ...
    adding FxCoil 'Torso_B' ...
    adding 2D-Sketch 'Foot_Leg_R' ...
        ... added Arc-Circle M=(-1.00002,3.16227) R=0.25, from 3.141592653589793 to 0.0 ...
        ... added line (-1.25002,3.16227)-(-0.750015,3.16227) False = 1
        ... added Circle M=(-1.25002,2.99644) R=0.05...
        ... added 2D-Ellipse  center=(-0.00578844,0) a=(0.0442116,0) b=(-0.00578844,-0.0474342) ...
        ... added line (-1.00002,3.16227)-(-0.00578844,0) False = 4
    adding FxCoil 'Leg_R' ...
    adding FxRevolve 'Foot_R' ...
    ... based on 'Foot_Leg_R' (full) ...
    adding 2D-Sketch 'Foot_Leg_L' ...
        ... added Arc-Circle M=(3.31667,-5.55112e-16) R=0.25, from 1.5707963267948966 to 4.712388980384688 ...
        ... added line (3.31667,-0.25)-(3.31667,0.25) False = 1
        ... added Circle M=(3.15084,0.25) R=0.05...
        ... added line (0,0)-(3.31667,-5.55112e-16) False = 3
    adding FxRevolve 'Foot_L' ...
    ... based on 'Foot_Leg_L' (full) ...
    adding FxCoil 'Leg_L' ...
DONE!
and some weird twists:
OS: Windows 8.1 (6.3)
Version: 0.19.21120 (Git)
Hash: 517ae79341b2c74af6574f7ae9f1de4e3e084c67
Python version: 3.6.6
Qt version: 5.12.1
sgrogan
Postby sgrogan » Wed May 20, 2020 8:17 pm
@apeltauer, what do you think about just adding this to the Libpack? I can do this for a 12.1.6 Libpack, but I don't want to get our versions crossed again. I can do the same for the Conda builds so these modules are available for linux and osx by default as well.
johnwang
Postby johnwang » Wed May 20, 2020 10:23 pm
Nice job.
apeltauer
Postby apeltauer » Thu May 21, 2020 7:23 am
Creating a new Libpack is a good idea.
