[Merged] Split Edge function for Sketcher
tpavlicek
Re: [Merged] Split Edge function for Sketcher
Post by tpavlicek »
Kunda1 wrote: Mon Apr 26, 2021 7:23 pm I've added mention this to the 0.20 release page but the documentation is still incomplete. I know this feature is still a work in progress nevertheless we should have some documentation explaining how to use it. Someone please step up, thank you!
Hi Kunda1,
I have tried to document the feature a bit, however I am quite a Wiki beginner, so it may not be according to the common expectations. I have also added the item to Sketcher Workbench Geometries commands overview, however I do not know what these <!--T:xxx--> HTML comments mean, so I rather skipped adding such a line.
Kind regards,
Tomas
Post by Kunda1 »
tpavlicek wrote: Tue Apr 27, 2021 10:26 pm I have tried to document the feature a bit, however I am quite a Wiki beginner, so it may not be according to the common expectations. I have also added the item to Sketcher Workbench Geometries commands overview, however I do not know what these <!--T:xxx--> HTML comments mean, so I rather skipped adding such a line.
Don't worry about the formatting, we can fix that.
The <!--T:xxx--> stuff is the translation addon for the wiki. Don't mess with those unless you know what you're doing.
bleber
Post by bleber »
Some possible improvement, Split edge on crossing lines.
LHC
Post by LHC »
Just a quick note and risking cluttering up this thread but had to say "Yay!!! Thanks for the function!" I just got aware of it when I recently downloaded the 0.20 weekly build. Will be using it ALL the time based on my workflow (or lack of organization when sketching :lol: )
HoWil
Post by HoWil »
It would be great if one could select an existing point instead of creating a new one.
BR
HoWil
HoWil wrote: Fri Mar 10, 2023 3:15 pm It would be great if one could select an existing point instead of creating a new one.
Can you elaborate how it should work?
HoWil
Post by HoWil »
chrisb wrote: Fri Mar 10, 2023 4:57 pm
Current behaviour:
Selecting the "Sketcher Split"-function lets you add a new point on an existing line. See also https://wiki.freecad.org/Sketcher_Split
New behaviour:
Selecting an existing point on an existing line and thereafter selecting the "Sketcher Split"-function does use the existing point for splitting the line similar to the newly created point from the current behaviour.
NewJoker
Post by NewJoker »
HoWil wrote: Fri Mar 10, 2023 5:07 pm New behaviour:
Right, I was also thinking about this. It would make it possible to split lines precisely using properly constrained points attached to them.
Some thoughts to be considered:
- Should it split all lines on which the point lies?
- What should happen if a point has a point-on-object constraint on a line, but is not lying on the line itself, but on its extension?
- Is a point being symmetric to the ends of a line considered to lie on the line (I think so)?
- point-to-line tangency should be respected
- point-to-line orthogonal should be respected
Are there more such cases?
