Arch survey tool
shoogen
Re: Arch survey tool
Postby shoogen » Thu Jun 05, 2014 6:44 pm
yorik wrote:Other things such as placements also use vector properties, they will also need a solution some day
They do it by now, don't they?
Postby yorik » Thu Jun 05, 2014 7:07 pm
Oh wow! I hadn't noticed. But the vector proporty apparently still doesn't use units. I'll have a look at how it is implemented for placements
Postby bernd » Thu Jun 05, 2014 7:31 pm
suggestion: a sum mode
checkbox --> if the checkbox is acivated a adding (sum) mode starts --> if the first shape is a face only faces are possible to click --> all areas of the clicked faces are added and couloured green for control --> if a face is clicked twice it gets the original colour again and the aerea is not added to the sum --> if the checkbox is clicked again the sum is printed.
same behavior for edges and volumes.
saso
Postby saso » Thu Jun 05, 2014 7:43 pm
bernd wrote:suggestion: a sum mode
+1
... i would go with the simple, fast and standard ctrl+click to add or remove from the sum and just update real time while the ctrl is down. could go with a different background color of the value to show it is a sum. 8-)
ps: speaking of keyboard keys, any reason why shift+middle mouse is not doing orbit in cad mode? :|
saso
Postby saso » Thu Jun 05, 2014 8:51 pm
and maybe changing the l, a, v with some mini icons like this below?
sumicons.svg
(6.7 KiB) Downloaded 92 times
icons.svg
(3.55 KiB) Downloaded 157 times
bejant
Postby bejant » Fri Jun 06, 2014 4:39 am
saso wrote:any reason why shift+middle mouse is not doing orbit in cad mode?
You could try MMB + LMB
(or try MMB + RMB, which is probably easier if you're right-handed...)
jmaustpc
Postby jmaustpc » Fri Jun 06, 2014 7:32 am
I modelled this concrete block, I wanted its volume of concrete used in its construction, so I thought I would try the Arch Survey tool to get the volume of the solid, but for me it did not work completely and would not give me the volume. I think the problem is I got an error message which then aborted the operation and when closed it left some of the annotations in the treeview.
Vertex - works
Edge - Works
Face - works
Click twice for solid - some results with error message
report view output
Object: Mirrored, Element: Vertex4, Zcoord: 180 mm
Object: Mirrored, Element: Edge10, Length: 190 mm
Object: Mirrored, Element: Face5, Area: 25,686.7 mm^2
File "/home/user/Downloads/cad/FreeCAD/clone2/build_master/Mod/Arch/ArchCommands.py", line 811, in addSelection
self.callback(True)
File "/home/user/Downloads/cad/FreeCAD/clone2/build_master/Mod/Arch/ArchCommands.py", line 867, in survey
anno.BasePosition = o.Object.Shape.CenterOfMass
<type 'exceptions.AttributeError'>: 'Part.TopoShape' object has no attribute 'CenterOfMass'
here is the fcstd file
concreteblock.fcstd
(15.88 KiB) Downloaded 59 times
here is a screen shot
FreeCAD data
OS: Ubuntu 14.04 LTS
Platform: 64-bit
Version: 0.14.3650 (Git)
Hash: 8dbbdd3dd86432a79149f8065731372a76fe2942
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
By the way since I couldn't get the volume from Arch survey I then tried the updated "info" WB from Keith sloan's website, it didn't work properly, the task view was empty and could not be cancelled. I ended up getting one of the Macros to work that Mario worked on and posted on the wiki.
Postby yorik » Fri Jun 06, 2014 10:31 pm
Wow, that's the first time I see a shape without CenterOfMass! It's a compound... I thought compounds had center of mass too. Anyway I'll fix that ASAP.
jmaustpc
Postby jmaustpc » Sat Jun 07, 2014 5:33 am
Hi Yorik
I tested a few Part and PartDesign shapes and since all Part Booleans and PartDesign Pattern features create a compound (usually a compound of a single solid) they (the compounds only) all produce this error. I made this test file with a few random Part and PartDesign shapes to test your Arch Survey tool. So I thought I would post it, in case it is of any use. :)
Jim
testshapesforcompound.fcstd
(68.46 KiB) Downloaded 59 times
Postby yorik » Sat Jun 07, 2014 3:13 pm
Ok this is now fixed. It estimates by the center of the bounding box, in case the shape doesn't have a center of mass... I also gave a bit of polish to the units. I noticed that even if you use the meters unit schema, areas and volumes still come in mm² and mm³. I'll try to fix that too
