Toup Workbench
ToupStudio
Toup Workbench
Post by ToupStudio »
Hi FreeCAD community,
I would like to share with you a project I've been working on for some time now.
Its objectives can be separated in two parts:
  1. API to ceate python-generated designs. Parametric on its sizes, finishes and materials
  2. Way to manage these generators and get CNC/laser jobs
Let me show you an example of how it works but skipping, for a moment, the first point. Let's suppose we have a script that generates boxes which accepts these parameters: length, height, width, numJoints and externalOffset and a material id (later defined) we want to use, mainly for its width. An example of a usage of these generator or ToupJob can be written as:
<ToupJob id="Box_Job">
	<ToupElement id="Box" name="regular_box">
		<Values length="500.0" height="500.0" width="500.0" numJoints="2" invisible="0.0"/>
		<Materials board1="86851000"/>
	</ToupElement>
</ToupJob>
Now, getting to the second point, we can define a ToupFactory that consists on a set of bits, a set of materials and the elements or generators we have. For example:
<ToupFactory id="toupmdc">
	<ToupBits>
		<ToupBit id="EndMill6mm" toolType="endMill">
			<Values diameter="6.0" totalLength="60.0" cuttingLength="30.0" rotation="negative" lips="1"/>
		</ToupBit>
	</ToupBits>
	<ToupMaterials>
		<ToupMaterial id="86851000" price="98.15EUR" type="board">
			<Info description="TAULER ENLLISTONAT PI INSIGNIS A/B 2400X1200X22"/>
			<Values height="1200.0" length="2400.0" width="22.0"/>
			<Cut bit="EndMill6mm">
				<CuttingParameters passDepth="9.0" stepOver="2.0"/>
				<FeedsAndSpeeds spindleSpeed="22000.0" feedRate="60.0"/>
			</Cut>
		</ToupMaterial>
	</ToupMaterials>
	<ToupElements>
		<ToupElement id="Box" path="furniture/box.py"/>
	</ToupElements>
</ToupFactory>
Now the previously defined job can be executed on the factory like this:
Or edit the Job to get a different finish and increase the quantity of boxes:
It also can be executed from the command line and has been tested on linux, mac and windows.
This is just a quick introduction and there are some other features that I can further explain. But I wanted to see if can be interesting to someone or read your comments
RatonLaveur
Re: Toup Workbench
Post by RatonLaveur »
Hi, that's really interesting work,
To me it should be showcased as well in the Path workbench forums, there are recurring discussions on how to adapt the path workbench for energy based cutters (laser, waterjet, plasma...)
https://forum.freecadweb.org/viewtopic. ... er#p490774
https://forum.freecadweb.org/viewtopic. ... er#p481390
As well as the Interlocking Module workbench
https://forum.freecadweb.org/viewtopic. ... ing+module
There is definitely a subset of the FreeCAD community who would be interested in smoother/new workflows catering to the needs of designing interlocking modules as well as cutting them for prototyping or production.
Varnu01
Invite to 2023 FreeCAD (and Free CAE) Users Conference
Post by Varnu01 »
Good Day @ToupStudio
My name is Varnu Govender, I am the assistant to Dr du Plessis at the University of Pretoria, South Africa.
We are organizing the 1st Annual FreeCAD (and Free CAE) Users Conference, which is set to take place in Early 2023.
I have taken interest in your Workbench, and I would love if you could present your work at the conference.
You are welcome to present your workbench in the following manner:
  • Introduction/Overview of your Workbench
  • Run-down on how the workbench operates through the user interface and backend.
  • A tutorial demonstrating the full functionality of the workbench.
  • A showcase of something that has been created/modelled in the workbench.
In addition to this, if you know somebody that might be interested in presenting their work during the conference, please could you refer them to me (@Varnu01.)
I hope to hear from you soon.
Regards
Varnu Govender
FreeCAD (and Free CAE) Users Conference 2023. Register Here
Nikra-DAP FreeCAD Workbench
