Heads up for those running archlinux, the freecad-git package has been added to chaotic-aur repo: https://aur.chaotic.cx/ https://github.com/chaotic-aur/packages/issues/774
Built daily from master, bear in mind this is an unofficial repository, use at your own risk.
If you don't want to add the whole repo you could just download the compiled package every now and then from http://mirrors.fossho.st/garuda/repos/c ... ur/x86_64/ and install with pacman -U
If you run Manjaro you can try that to, I don't recommend adding the repo, and maybe even keep a backup of the last working version in case a dependency is upgraded in archlinux and not yet in Manjaro resulting in a broken package in Manjaro.
freecad-git package added to chaotic-aur repo
- adrianinsaval
