[fcxref] External Cross-Document Reference & Links Manager
Announcing "fcxref" (FreeCAD external references), a project that aims to make managing "external" or "cross-document" references or "links" easier!
Please see the GitHub repository for more information:
https://github.com/gbroques/fcxref
MOTIVATION
I'm currently working on a FreeCAD project that involves a "Master" or "Main" spreadsheet and many documents (~65) that reference aliases in this spreadsheet.
It became increasingly difficult to know all the places where I was referencing aliases in the "Main" spreadsheet, and even more difficult to rename them.
To make this easier, I created "fcxref" (FreeCAD external references), a project that does this by parsing the Document.xml files in compressed .FCStd files.
I'm looking for feedback, testers, and to start a dialogue about changes or improvements.
Please post feedback in the corresponding Users Showcase post:
https://forum.freecadweb.org/viewtopic.php?f=24&t=60733
YouTube Demo
https://www.youtube.com/watch?v=Ng3kLWpiIT4
MOTIVATION
YouTube Demo
Re: [fcxref] External Cross-Document Reference & Links Manager
CC @realthunderrealthunder wrote:heads up
I don't think this project impacts realthunder directly.
Of course his changes to FreeCAD may break my code.
I can certainly see him implementing similar functionality in FreeCAD core that makes this project obsolete.
Does anyone know if his FreeCAD fork has this functionality already, or if anyone has definite plans to work on this?
@gbroques can you provide a demo or a screencast of this feature in action?
There is a feature already in upstream, but I am not sure if this can achieve the same thing you want. Right click any item in the tree view, and select 'Expression actions -> copy all documents'. Open any text editor and paste to get all expressions in all documents in a readable format. You can add/remove/modify expressions, change binding property, change alias, etc. Just copy the modified code and use 'Expression actions -> Paste'.
I added this for easy access to all expressions in one go. also because expression in my branch can be a full program. See an example here. It would be better to have a dedicated editor with expression completer for that, in the future maybe.
It's a definite step in the right direction and certainly helps! Thanks for chiming in on this.realthunder wrote: ↑Mon Aug 02, 2021 8:33 am There is a feature already in upstream, but I am not sure if this can achieve the same thing you want. Right click any item in the tree view, and select 'Expression actions -> copy all documents'. Open any text editor and paste to get all expressions in all documents in a readable format. You can add/remove/modify expressions, change binding property, change alias, etc. Just copy the modified code and use 'Expression actions -> Paste'.
By "upstream", do you mean your fork and or is there plans to contribute this feature back to FreeCAD?
I was wondering if there's a PR or something I could maybe track.
I've had my eye on Configuration Table using Spreadsheet #2862 with eager anticipation.
- adrianinsaval
I think it's been there for a long time, maybe even since Links were added. It's also in the stable 0.19 release
Thanks! I didn't read the page realthunder linked to closely enough and failed to realize you had to right-click the Spreadsheet object to see Expression Actions.adrianinsaval wrote: ↑Mon Aug 02, 2021 2:59 pm "Upstream" is the main FreeCAD. Just checked and it is there in 25367 (local build form today), not sure since when.
I had no idea this functionality existed until now, so I appreciate you two pointing it out to me.
