Addon Manager Redesign 2021
chennes
Re: Addon Manager Redesign 2021
Post by chennes »
Your understanding of the .gitmodules file is basically correct, with the caveat that the Addon Manager assumes that the submodule name and path are identical. The name the Addon Manager displays is whatever it finds in the <name></name> element of package.xml -- if that is absent, then it uses the data from .gitmodules.
Chris Hennes
Pioneer Library System
onekk
Post by onekk »
chennes wrote: Thu Sep 15, 2022 6:46 pm ...
Thanks.
I will do some test.
At a first glance itseems that the submodule is used even when the name tag is present and different in package.xml.
But I have to check better as probably there could be some problem with package.xml file and my actual installation of FC 0.21 seem not to have the developer tools.
Regards
Carlo D.
- Various other stuffs.
chennes
Post by chennes »
Developer Tools is brand new, I added it at the beginning of this week.
Chris Hennes
leoheck
Post by leoheck »
Hi Chennes, I was removing some old plugins and I got this issue here:
➜  Applications Traceback (most recent call last):
  File "/tmp/.mount_FreeCAVnTdLM/usr/Mod/AddonManager/AddonManager.py", line 547, in reject
    thread.wait(25)
KeyboardInterrupt
  File "/tmp/.mount_FreeCAVnTdLM/usr/Mod/AddonManager/manage_python_dependencies.py", line 54, in run
    if check_for_python_package_updates():
  File "/tmp/.mount_FreeCAVnTdLM/usr/Mod/AddonManager/manage_python_dependencies.py", line 64, in check_for_python_package_updates
    outdated_packages_stdout = call_pip(["list", "-o", "--path", vendor_path])
  File "/tmp/.mount_FreeCAVnTdLM/usr/Mod/AddonManager/manage_python_dependencies.py", line 92, in call_pip
    if proc.returncode != 0:
UnboundLocalError: local variable 'proc' referenced before assignment
OS: Ubuntu 22.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.30377 (Git) AppImage
Hash: 2462f4c7a05745488bb9e81ccc7ba0f386f78849
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Part-o-magic.backup1662467294.9039905
  * A2plus 0.4.59
  * Curves 0.5.8
  * fasteners 0.4.6
  * lattice2 1.0.0
  * Assembly4 0.12.4
  * kicadStepUpMod 10.15.1
  * Help 1.0.3
chennes
Post by chennes »
Thanks for the report -- I'll get that cleaned up shortly.
ETA: git commit ebb32633d8
Chris Hennes
KAKM
Post by KAKM »
Is there a way to update the addon manager through the addon manager? If not, how do I go about it? It ate my CfdOF install, tells me it's still there, crashed when I tried to uninstall and reinstall, and before I report this as a bug I'd like to make sure you haven't fixed it already.
chennes
Post by chennes »
No, the Addon Manager isn't itself an Addon, so the only "update" to it is to update your FreeCAD. Can you paste in your version info?
Chris Hennes
adrianinsaval
Post by adrianinsaval »
chennes wrote: Fri Sep 16, 2022 3:59 am No, the Addon Manager isn't itself an Addon, so the only "update" to it is to update your FreeCAD. Can you paste in your version info?
maybe it should be one? I think it's written in python right?
KAKM
Post by KAKM »
Bummer. The last time I tried to update FreeCAD for a bug fix being a bit aggravating because the homebrew builds were way behind the weekly.
chennes wrote: Fri Sep 16, 2022 3:59 am Can you paste in your version info?
OS: macOS 10.15
Version: 0.20.28901 +1 (Git)
Branch: ipatch.builds.git.master.head.may10
Hash: 778a95f27e26e040ff29599847a224d44b7a5fa7
Python 3.10.4, Qt 5.15.3, Coin 4.0.1, OCC 7.5.3
Installed mods:
  * Tutorial-dev
  * CfdOF
  * CfdOF.bak
  * Tutorial-dev.zip
Oh, and even though it claims that CfdOF is installed, the folder is empty. I tried deleting that folder to see if I could reinstall without a crash this time, and it still hung up a very small percentage of the way in, according to the progress bar. Clicking on the install button a second time crashes FreeCAD, which is exactly how it happened the first time around.
onekk
Post by onekk »
... Amended post moved in the right forum thread.
Regards
Carlo D.
